Problem please help
Discussion in 'New Members' started by DogMan, Jun 2, 2013.
  1. Jun 2, 2013 at 11:52 AM
    DogMan
    DogMan [OP] New Member
    When I try to start my 1989 Toyota two wheel drive four cyl, the check engine light flashes I have to hold the gas to the floor truck will start and run for 30-40 seconds then die while it's running the check engine light flashes motor sounds like its on a rev limiter changed coil and igniter have power / fule pressure any ideas
  2. Jun 2, 2013 at 12:15 PM
    KodiakToyTRD
    KodiakToyTRD Well-Known Member
    CO
    2013 Scion FR-S Whiteout
    More punctuation.
    It will sound like its on a rev limiter if you keep your foot on the gas all the way down for 30-40 seconds.
    Bad fuel
    Bad fuel pump
    Dirty MAF
