Problem: Transmission Sticking In Neutral
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NeoMoose, Jan 4, 2010.
  1. Jan 4, 2010 at 8:24 AM
    NeoMoose
    NeoMoose [OP] Possibly Batman
    Houston, TX
    2010 PreRunner DC TRD O.R.
    Kenwood eXcelon X993, Kenwood KFC-1693PS (Front), Kenwood KFC-G1620 (Rear), Luverne Black Nerf Bars, OEM Brush Guard, AFE Pro Dry S Drop-In, Some kickass wheel locks, Removed front mud flaps, All windows tinted, Anti-theft tailgate mod
    Obviously, this is going to the shop since it's brand new and under warranty, but I'm curious if anyone here has experienced a similar issue and what the problem is.
    My automatic transmission, when doing standard highway driving, will sometimes stick while shifting. Usually right at about 35 mph, if the RPM's are just right, it'll go to shift but stick in neutral, causing the engine to redline (with no power being sent to the wheels, this is what makes me assume it's sticking in neutral). I'll have to screw around with the gas/brake pedals to trick the transmission into shifting again to bring it back home. Doesn't happen a lot, but at least once every 2 days or so, sometimes multiple times in a day. Very intermittent.
    Not very happy that I have a powertrain problem with less than 2000 miles on my truck.
    Anyways, has anyone had a similar issue? What did it turn out to be?
    :confused::confused:
    EDIT: apparently the correct term for it is slipping and not sticking...
  2. Jan 4, 2010 at 8:56 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Take it in.
  3. Jan 4, 2010 at 9:01 AM
    NeoMoose
    Houston, TX
    Appointment is at 2pm. Maybe I can get the TSB done on it while I am there.
  4. Jan 4, 2010 at 9:03 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    22 JLUR 6MT
    Get a 6-speed ;)
    Maybe the TSB will help.
  5. Jan 6, 2010 at 12:16 PM
    NeoMoose
    Houston, TX
    Ugh. Frustration. Drove around with the mechanic for about 20 minutes and couldn't get it to slip while I was driving it. Told him it's happening at least every other day, but it isn't very often only made him tell me it was an "unusual complaint" and that "hopefully it will get worse so you can show it to us because we can't fix it otherwise"
    So here's to hoping my transmission explodes.
  6. Jan 6, 2010 at 1:11 PM
    roy826
    roy826 Well-Known Member
    Mississippi
    2010 Prerunner TRD Sport DC
    Mine has a slipping sensation also almost like it clutches it's way into a gear. Very odd and I have lived with it for 3k miles. It goes in tomorrow and I am not very happy about it:mad:
  7. Jan 6, 2010 at 8:07 PM
    NeoMoose
    Houston, TX
    Let me know what they tell you, if we have similar problems it may help me get to the bottom of getting my stuff fixed.
  8. Jan 6, 2010 at 10:16 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    That was my first though to... TBH I'm surprised the stealer didn't at least check that while you were there.
  9. Jan 7, 2010 at 3:31 AM
    roy826
    Mississippi
    That would be so easy to check IF the thing had a dipstick. Bad design IMO. we all have better things to do than run to the dealership 24/7 for a check on something that up until now has been rather easy to do yourself.:rolleyes:
