Problem w/ Driver Side, Cabin Side Spark Plug Boot
Discussion in '1st Gen. Tacomas (1995-2004)' started by TeleBlaster, Aug 21, 2017.
  1. Aug 21, 2017 at 12:30 PM
    TeleBlaster
    TeleBlaster [OP] Member
    Michael
    Tampa, FL
    04 SR5 TRD Double Cab
    Supercharger, cat-back
    Checking out some engine noise, I noticed that the driver-side, cabin-side spark plug boot was lifted up a bit. I tried, unsuccessfully, to push it down.
    Being the brilliant guy that I am, I decided I'd pull it out. With a lot of effort, I was able to pull the boot up and mostly out. Now, I can't get it pushed down as far as it had been.
    This hose is making accessibility harder. What is this hose, and can I simply unplug/replug it?
    Also, what kind of damage (if any) can I expect from having applied considerable downward force on the boot?
    Thanks, in advance, for any replies.
  2. Aug 21, 2017 at 1:04 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    You can unbolt that bracket. I'm pretty sure the hose is fine to undo as well.
    The boot just houses a spring so make sure it looks like any of the other boots / springs that you didn't have a hard time with and you should be good. If it was damaged you'll have a misfire in that cylinder.
    TeleBlaster[OP] likes this.
  3. Aug 21, 2017 at 1:33 PM
    TeleBlaster
    Michael
    Tampa, FL
    Thanks.
    Dalandser[QUOTED] likes this.
  4. Aug 21, 2017 at 1:53 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    You're welcome!
  5. Aug 21, 2017 at 2:01 PM
    Itchyfeet
    Itchyfeet Well-Known Member
    It might be a good time to throw some dielectric grease on those boots. When they get stuck they can be a real pain to pull off.
  6. Aug 21, 2017 at 2:16 PM
    TeleBlaster
    Michael
    Tampa, FL
    The terminal is off-center, which is probably why I'm having a problem getting it back on the spark plug.
    Any suggestions on how I can line that up with the spark plug terminal?
  7. Aug 21, 2017 at 2:26 PM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
    Replace the wires.
  8. Aug 21, 2017 at 2:28 PM
    TeleBlaster
    Michael
    Tampa, FL
    Dammit.
  9. Aug 21, 2017 at 2:54 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I have a spare set I just took off of my truck if you'd like them so you can replace it with. Nothing wrong with it - just bought an engine with good plugs and wires so mine can go to you. PM me if your'e interested!
  10. Aug 21, 2017 at 3:20 PM
    TeleBlaster
    Michael
    Tampa, FL
    Wow. That's really appreciated, but my local parts shop has it in stock and I'm going to pick it up, tonight.
