problem w/ elect. lighting, turn signals, brake lights...
Discussion in '1st Gen. Tacomas (1995-2004)' started by cheffboy3030, Jun 13, 2010.
  1. Jun 13, 2010 at 9:59 PM
    cheffboy3030
    cheffboy3030 [OP] wheelinAZ
    Richie
    Tempe, Arizona
    01 2.4L 2wd standard
    K&N intake, MAGNAFLOW exhaust, PROCOMP es3000 shocks, 1.5" front coil spacers, BFG KM2 mud tires, black UNIQUE 297 off road wheels, modified front bumper, PROCOMP 55 fluted lights, aftermarket tow hooks, BLACKED OUT everything, ALPINE deck, JL AUDIO sub
    I have an 01 tacoma with 182k and experiencing problems with electrical lights. My brake lights turn on instantly when I turn on my head lights, my turn signals blink really fast, my AC button lights blink simultaneously with my blinkers, and just now my blinker lights quit working all together (Neither the lights nor the arrows on the dash work). I believe this is caused by the multifunction switch (turn signal switch knob) and that it needs replacement. Before I spend large amount of money on this small electrical component I would like to know if anyone else has experienced this? And if there is anything else that could cause these problems? - thanks for your input
  2. Jun 13, 2010 at 10:38 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    I think you might have a bad ground somewhere. Did you just install a hitch for a trailer?
  3. Jun 14, 2010 at 4:49 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    If the brake lights are involved, I doubt the cause is the combination switch alone. Sounds more like a short or bad ground in the wiring leading to the rear. Such weirdness is common when a trailer harness goes bad.
  4. Jun 14, 2010 at 8:42 AM
    cheffboy3030
    Richie
    Tempe, Arizona
    I don't have a trailer harness hooked up or any additional wiring for that matter and the brake lights ONLY become involved when I turn my head lights on (which are controlled by the multifunction switch). When I am not engaging that switch everything works fine. I will take it apart and look for a short in that switch wiring system and see if its as simple as that.
  5. Jun 14, 2010 at 8:54 AM
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    02 DCSB prerunner 4x4 manual
    sounds like a bad rear harness until you said a/c light never heard that one before
  6. Jun 14, 2010 at 9:08 AM
    EnolaGaia
    Midwest USA
    '01 & '04 S-Runners
    Is the A/C switch lamp the only dash light (other than the turn signal indicators) that acted weird?
    The combination switch has nothing to do with the brake lights, so it's unlikely whatever is cross-juicing the brake light circuit is occurring within the switch assembly itself.
  7. Jun 14, 2010 at 9:25 AM
    cheffboy3030
    Richie
    Tempe, Arizona
    The AC lights are the only dash lights acting funny, but what makes me believe the brake lights could be caused by this switch is that they don't FULLY light up. They light to about 90% illumination, acting as a running light that's very very bright. They're supposed to light up dimly when my headlights are on but they're lighting up way too much
  8. Jun 14, 2010 at 9:42 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Trace your headlight wiring back to the source. Pay close attention to where it's bundled with other wires. It"s most likely when it runs through a pinch point. Ie. Grommet or zip tie etc.
    I doubt it's a switch or trailer harness, unless it's routed with the headlight wires.
    Check all grounds as well. Bad or missing grounds cause some really weird problems.
    Check for frankenstien circuits(mess of wiring for aftermarket components). Those could be suspect as well.
    Good luck! Shorts to power are tricky to pinpoint.
  9. Jun 14, 2010 at 9:44 AM
    EnolaGaia
    Midwest USA
    '01 & '04 S-Runners
    The brake light circuit is apparently getting current from some circuit controlled by the combination switch, but it can't be getting this cross-current from the switch itself.
