Problem with 05 leaf springs.
Discussion in 'Suspension' started by Jamie R. Cherry, Dec 8, 2009.
  1. Dec 8, 2009 at 3:54 PM
    Jamie R. Cherry
    Jamie R. Cherry [OP] Member
    Jamie
    Schuylerville,N.Y.
    05 tacoma Double Cab
    I stumbled upon this site while looking for any recalls on my truck leaf springs. I found some TSB's but no recall info yet. Has anyone had any luck with tsb's or heard of any recalls. My leaf springs have bottomed out from day 1. Had shocks replaced from dealer because they also failed. HELP!
  2. Dec 8, 2009 at 3:59 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    The leaf springs won't be re-called. They're not a 'safety hazard'.
    They will probably always remain a TSB and the work is free if you're still under the factory warrantee.
    The only recall notice that I've received via Toyota, is the letter to remove the floor mats. There is talk about another recall to have the gas pedals cut - but I haven't received any official notice about that yet.
  3. Dec 8, 2009 at 3:59 PM
    JTaco386
    JTaco386 Well-Known Member
    JT
    Fort Rucker, AL/ Home: Port Orange, FL
    13 DCSB TRD Sport 4x4
    Use the search engine on the forum. Theres a tsb out to replace the leafs to accomodate the "harsh ride." if you have a non trd they also replace your shocks to billsteins. I don't know if they will replace yours unless you're under warranty still. Good luck
  4. Dec 8, 2009 at 4:21 PM
    Jamie R. Cherry
    Jamie
    Schuylerville,N.Y.
    Thank you all that replied. I spoke with a service rep and he informed me that it will cost me something. He's seeing what toyota will do for me? I'll post my results. Thanx again.
  5. Dec 10, 2009 at 2:15 PM
    Jamie R. Cherry
    Jamie
    Schuylerville,N.Y.
    I spoke w/ the dealership and it will cost me $1241.16. They are only charging me for 1hr. labor! Imagine that. I'll keep you posted.
  6. Dec 10, 2009 at 2:29 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    You can buy a new leaf set for less than half that.....
  7. Dec 10, 2009 at 2:30 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    ill do it for you: new leafs, bushings, and shocks along with 150 point inspection for $1000
  8. Dec 10, 2009 at 2:36 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If you end up going with the dealer, remember to bring lube:
  9. Dec 10, 2009 at 2:44 PM
    08pretaco
    Oliver
    az
    i started crying after i saw that
  10. Dec 10, 2009 at 2:45 PM
    08pretaco
    Oliver
    az
    ill even bake you a cake for the grand...with coffee!
