Problem with ABS
Discussion in 'Technical Chat' started by lookitsBRYAN757, Feb 17, 2013.
  1. Feb 17, 2013 at 7:15 AM
    lookitsBRYAN757
    lookitsBRYAN757 [OP] Active Member
    Bryan
    NN VA
    07 Tacoma, 05 4Runner
    So on Monday I took my 07 taco to the dealership where I bought it and where my warranty is. I'm getting ready to go on a long drive and wanted to get an oil change and alignment. They then found a bad wheel bearing. So they replaced the bearing and hub. Upon test driving it after the repair they noticed the ABS light was on. The only light that's ever came on is the maint reqd light. So they take it over to the Toyota dealership and they can't get any communication between the scanner and the ecu. They're saying they might have to replace the whole ecu. Has this happened to anyone else?
  2. Feb 17, 2013 at 10:29 AM
    Tacoma Mike
    Tacoma Mike 42 Year Toyota Master/ASE Master Tech.
    Southern Maine
    2011 Double Cab V6
    Large Storage Box, 02610 intermittent switch swap, "Hot Wire" Power Outlets, DRL Shut Off, Disable Fob Beep, Disable Seat Belt Buzzers, Parking Light Mod, Battery Tender, 4 Leaf Spring Pack, Rear Headrest Removal, Custom Ultragauge Mount, Factory Tow Package (7 Pin) Rear Diff Mod, Taco Lean Mod
    Could have stretched the sensor wire or damaged the tip.
    As far as not reading the ecu, it does happen however, we have been having a few issues with connecting to them from time to time. I have had to reboot the scan tool and then it would read. I doubt if you have an ecu problem after a bearing replacement and THEN an abs lamp on.
  3. Feb 17, 2013 at 10:39 AM
    IgnorantlyAlberta
    IgnorantlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    They probably messed up the abs sensor when replacing the bearing. I did this when i replaced mine.
    Fragile, expensive little bastard.
  4. Feb 18, 2013 at 12:30 AM
    lookitsBRYAN757
    Bryan
    NN VA
    Yeah I hope it's nothing to serious I just want my truck back they got me in a yaris :/ thanks for the info
  5. Feb 18, 2013 at 12:41 AM
    650H1
    650H1 Well-Known Member
    NH
    2010 Tundra TRD OR C/M 5.7l 4x4
    thats like a street legal go cart dude... fun cars to hammer the fuck out of, especially when its not yours :p
  6. Feb 20, 2013 at 3:27 AM
    lookitsBRYAN757
    Bryan
    NN VA
    Yeah not when the thing takes two years to get up to 80
  7. Feb 21, 2013 at 3:34 PM
    lookitsBRYAN757
    Bryan
    NN VA
    So if anyone was wondering what was going on today I was told that the speed sensor on the same wheel bearing and hub that the first dealership worked on the wire was pulled and snapped but they don't see and connection between that wire being pulled to the other two wires that were supposedly "cut."
  8. Feb 21, 2013 at 4:52 PM
    IgnorantlyAlberta
    David
    edmonton
    That sucks.
    Sabotage??
    Where was your vehicle being serviced before this issue?
    It sucks cause when a bearing goes you can bet the sensor will be done as well so its an extra cost.
    However when you have someone cutting wires youve got other problems.
  9. Feb 22, 2013 at 4:55 AM
    lookitsBRYAN757
    Bryan
    NN VA
    I took it to the dealership that i bought it and i have a warranty. And I really can't do anything about it because the shop that I got my radio installed at went out of business and I can't find the receipt anywhere. But they're trying to tell me that those wires being cut had nothing to do with the lights coming on. So basically what I feel like is when I've brought my truck in before that this wasn't there before. I got that radio installed the very next day after I bought the truck.
  10. Feb 22, 2013 at 7:22 AM
    BamaToy1997
    BamaToy1997 ASE Master Tech Vendor
    Bill
    Navarre, FL
    Multi-point tow hooks, new bored 2.7L engine, custom paint. 3 inch adjustable Fabtech front coils, 2.5 inch rear AAL. Front Aussie locker. LED bed lights. Full LED conversion interior and exterior. Relentless Fabrication front and rear bumpers. 4X4innovation sliders. BAMF bed rack. CVT rooftop tent.
    ABS sensors are typically only replaced when they fail, due to the high cost. I have never worked in a shop where the sensor was replaced with the bearing, unless if was a complete unit. Too expensive otherwise.
  11. Feb 22, 2013 at 5:11 PM
    lookitsBRYAN757
    Bryan
    NN VA
    Yeah so now they said it is the reductor. They have to now do everything over including the bearing and hub, speed sensor and reductor...
  12. Feb 22, 2013 at 11:44 PM
    IgnorantlyAlberta
    David
    edmonton
    Just what Ive seen with both my bearings.
    One shit the bed and destroyed the sensor and I believe the other was wrecked from excessive heat. Either way when I had to replace the bearings the sensors were done too.
  13. Feb 23, 2013 at 6:43 AM
    BamaToy1997
    Bill
    Navarre, FL
    I believe the term they should have told you was the reluctor, not the inductor. I assume they will be doing all of this at no additional cost to you?
  14. Feb 23, 2013 at 7:25 AM
    lookitsBRYAN757
    Bryan
    NN VA
    Yes reluctor stupid auto correct. But yeah they are doing it all over again at no charge to me.
