Problem with amplifier - troubleshooting
Discussion in 'Audio & Video' started by Ronn, Oct 27, 2012.
  1. Oct 27, 2012 at 2:50 PM
    Ronn
    Ronn [OP] Well-Known Member
    Ron
    Northern Ontario
    2007 DCLB 4x4 SR5
    Westin bullbar, KC slimlites, Mini D2S headlight retrofit, 5100 front @ 1.75 and 5100 rear, Wheelers HD leaf pack
    Hey guys, the other day both my front components cut out. They are running off of a small 2 channel amp. It seems like the amp may be the problem but I'd like to run it by you guys in case I missed something.
    Things that I checked which are good:
    - Fuse on amp good
    - Main fuse good
    - All stereo connections in the truck are soldered, heat shrinked and taped
    - Connections at both speakers in the door are soldered
    - Checked the speaker wire and does not seem pinched anywhere (I didn't rip the truck apart though)
    - Power, ground, remote. The amp actually turns on.
    - Thinking it may be a bad rca cable, switched the rca from the sub(which works) over to the component amp and got nothing
    - Thinking it may be a bad rca output on the deck switched the rcas from the front to the sub up to the highs and got frequencies out of the sub
    I know basic troubleshooting and wiring so if you guys know any more tests I can run let me know. I'd like to be 100% sure it's the amp before I go and spend the money on a new one.
  2. Oct 27, 2012 at 7:41 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    If you switched your RCA's to another amp, and it worked... you can rule out your head unit and RCA's. The problem will be at your amp. If you're getting power on lights and no protection circuits then I'd be willing to bet your amp is broken.
  3. Oct 27, 2012 at 8:01 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Got to be the amp.
    You confirmed your other wiring (power etc) is working. You then tried the RCA's from the other amp working and your amp did nothing...that rules out the RCA's.
    Lastly, you got power out of the speaker when you plugged your questioned amp to it. That's the clincher.
    Amp shopping time for you..sorry to say it but that's the tests I would have done myself after 20 years of doing it and your amp is the culprit.
  4. Oct 28, 2012 at 8:53 AM
    Ronn
    Ron
    Northern Ontario
    2007 DCLB 4x4 SR5
    Thanks guys, wasn't sure if I would be able to do a test with the multimeter on the output channels of the amp. One thing I didn't do is to switch the speaker wires over to my mono sub amp to see if I get anything out of the components. (to rule out speaker wires being pinched somewhere)
  5. Oct 28, 2012 at 10:01 AM
    ABA180
    East Bridgewater MA
    I'd give that a go just to be sure, but my overwhelming sense is that you already have your answer..
  6. Oct 28, 2012 at 10:36 PM
    pinktaco808
    pinktaco808 Hot Steppa
    gain to high?
  7. Oct 31, 2012 at 5:12 PM
    Ronn
    Ron
    Northern Ontario
    2007 DCLB 4x4 SR5
    Yes. The speakers were working, I shut the truck off and went into a store. Then when I came back out and turned it back on the speakers didn't work.
