Problem with braking over bumps/ruts
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GearBox, Aug 1, 2011.
  1. Aug 1, 2011 at 11:22 AM
    GearBox
    GearBox [OP] I hate Commie Libs!
    Gear
    Phoenix
    07 Tacoma Double Cab TRD Sport 4x4
    Hey Gang,
    I am having and issue with my brakes and I will try to explain it as best as I can. I have noticed that if I am going over ruts/bumps in the road while braking it feels like my braking power goes down to like 20% and I really have to slam on the brakes to stop. The last time it happened is when I was braking on and area that had a bad transition from asphalt to concrete (Freeway overpass). I don't know if its something with the ABS, something is loose, or what. Please let me know if you have any ideas.
    Additional info for troubleshooting:
    OME lift and Dakar Spings in the rear
    No aftermarkets UCA
    Just got new pads and the rotors turned (Not related to issue just needed them done)
    Please let me know if you need more info on my rig.
  2. Aug 1, 2011 at 11:34 AM
    wmdpowell
    wmdpowell Well-Known Member
    Bill
    Selkirk, NY
    4x4 reg cab, 5 speed
    Better tires Hurcules Terra Track, trimmed front mud flaps, (access limited tonneau-took off) softopper, ats running boards, Piaa fogs, window vents, Wireless thermometer, extra bed rings, valley hitch
    Could it be bad shocks? If tire is in air or not firmly on ground the brakes won't get enough grip.
  3. Aug 1, 2011 at 12:04 PM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2002 Sliver-ade-o 2008 P71
    Yes
    I'm gonna guess crappy ABS. I've had some close calls in the winter and rainy roads myself.
  4. Aug 1, 2011 at 12:13 PM
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
    That is abs for you
  5. Aug 1, 2011 at 12:17 PM
    MontanaTaco
    MontanaTaco Well-Known Member
    Colter
    Relocated to Albany, NY
    14 DCLB Sport
    OME lift
    Yeah mine does the same if I brake over big bumps. Good ol' abs....terrible for stopping distance but good for a sraight line/control.
  6. Aug 1, 2011 at 12:20 PM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    ABS. There is an ABS kill switch mod for when off roading around here somewhere. Search for it.
  7. Aug 1, 2011 at 4:42 PM
    GearBox
    Gear
    Phoenix
    For the guys that say its ABS, is this just normal behavior or should I get it looked at? I mean there has been a couple of times where it definitely got my attention.
  8. Aug 1, 2011 at 4:43 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    You should try it on snow , it's horrible for stopping distance
  9. Aug 1, 2011 at 4:54 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    LED Headlights
    When you go over ruts/bumps, the tire has far less traction, so the ABS is probably releasing the brakes to avoid lockup.
    If you actually did a scientific comparison - going over the same stretch of road with ABS off then on, back to back, the stopping distances will probably be the same.
  10. Aug 1, 2011 at 4:55 PM
    MontanaTaco
    Colter
    14 DCLB Sport
    OME lift
    No I think you will be fine. I know my abs has woke me up more than once, its rather annoying but it is just sensing wheel motion.....its really bad for stopping on snow as oz said.
  11. Aug 1, 2011 at 7:19 PM
    GearBox
    Gear
    Phoenix
    OK guys thank you for your knowledge. If it was something I needed to get looked at I just wanted to make sure I take it in before the warranty was up :D
  12. Aug 1, 2011 at 7:47 PM
    cummins6speed
    It is normal operation. When you hit a bump the ABS computer thinks you are losing traction
  13. Aug 1, 2011 at 8:08 PM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    Millions
    If your truck beeps at you, and you see flashing lights on your gauge cluster, when this is happening then it could be VSC activating.
