problem with cab air system?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tisher49, Mar 22, 2010.
  1. Mar 22, 2010 at 6:31 PM
    tisher49
    tisher49 [OP] Well-Known Member
    Alex
    Orange, Virginia
    '08 4.0L 4x4
    K&N Air Filter, Westin Bull Bar with PIAA fog lights, Retrax cover, Alpine Head unit with I-Pod interface, maglite mount, Color matched grill surround w/ Grillcraft mesh
    so I have no clue if the title is the right way to describe my issue but i tried searching a few different things and didn't come up with anything...I've noticed that if i turned my fan control to "off" i still get a considerable amount of air coming through the vents. If I change the temperature on the controls the temperature of the air coming through changes. Also if I change where the air is going (just feet, feet and higher vents or just vents) i can feel the air change directions. I'm just trying to figure out if this normal or if there's something wrong with my truck. It's not a huge deal but I figure I might as well try to get it fixed while my truck is under the extended warranty. Thanks in advance.
  2. Mar 22, 2010 at 6:32 PM
    trd09
    trd09 Well-Known Member
    Chuck
    MA
    09 TRD Sport AC 4x4
    4-leaf TSB, 5100s @ 1.75, Flowmaster 40, Undercover Tonneau, K&N drop-in, Nittos, NGK Iridiums, OME N182s
    normal
  3. Mar 22, 2010 at 6:33 PM
    tisher49
    Alex
    Orange, Virginia
    '08 4.0L 4x4
    ok thanks...and props for probably the fastest response in history lol
  4. Mar 22, 2010 at 6:45 PM
    Super Werty
    Super Werty Sleeper 4x4
    Arizona
    07 TRD Tacoma
    air and fuel
    Try the recirculation button.
    It's in between the hot/col dial and setting dial. When that is pushed in and lit up your truck should be sealed pretty good.
    I dont feel any outside air blowing on me anyways.
  5. Mar 22, 2010 at 6:47 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
  6. Mar 22, 2010 at 6:49 PM
    tisher49
    Alex
    Orange, Virginia
    '08 4.0L 4x4
    alright i'll give that a try n see if that helps...thanks for the tip
  7. Mar 22, 2010 at 6:52 PM
    B_brand
    B_brand Well-Known Member
    Brandon
    Oklahoma
    I assume you only feel air blowing out when driving? It is because the recirculate button is not pressed and outside is being forced into your truck because you are driving into it. When you are stopped and the fan control is off you should not feel any air. Hope this helps.
