Problem with door sensor
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 311offroad, Mar 10, 2013.
  1. Mar 10, 2013 at 2:57 PM
    311offroad
    311offroad [OP] Stock Taco For Now
    Milledgeville, GA
    2005 TRD OffRoad SR5 4x4 Short Bed Debadged
    20% tint, Debadged, Pioneer AVIC-Z110BT, Infinity component door speakers, MagLite mod
    Recently my door sensor has been acting funny - with the door open the dome light goes on and off, sometime when i get out of the truck i guess it never registers that the door opened so my headlights stay on and I have to turn them off manually. Anyone else have this problem? Is this sensor on the inside of the door where the plastic piece that holds the door open slides in and out?
  2. Mar 10, 2013 at 3:04 PM
    Raceline08
    Raceline08 Well-Known Member
    Brett
    Santa Rosa, ca
    Silver 08 DBC SB 4x4 TRD Offroad
    front Billies, 885x coils, taco lean spacer, TC UCA'S, Magnaflow 22" OME Dakars, Billy 110 rear's, B.A.M.F CMC, custom made E-locker guard
    I don't know? I don't leave my headlights on all the time or have my done light turned on when the door opens, you could manually turn the headlights off and keep the done light off and not have a problem for now? I guess maybe a quick fix till you figure out exactly what's messed up?
    Thanks
    Brett
  3. Mar 10, 2013 at 4:55 PM
    311offroad
    Milledgeville, GA
    Any other suggestions? Anyone at least know where this sensor is?
  4. Mar 10, 2013 at 6:42 PM
    Kulahaga
    Kulahaga Tacomaized
    Roger
    Florida Panhandle
    2010 * Regular Cab * 2.7 * Manual
    Curt Receiver Hitch * Firestone RideRite Air Springs * OEM Chrome Grill * OEM Intermittent Wipers * OEM Cruise Control * UltraGauge * * Anytime Fog Lights * Cargo Bar & Cargo Net * Pop & Lock and Bully Tailgate Security * TonnoPro Tri-Fold Tonneau Cover * Backup Camera * * LED Interior, Under Door, Under Hood & Cargo Lighting * Pin Stripes * Wet Okole Seat Cover * ImMrYo Mirror Mod * DVR207 Dash Camera *
    As you open the driver's door, look at the right side of the door jam. You'll see a rubber covered pin switch. Try pushing it in and out and wiggling it to see if it's securely in place. It may not be making a good ground contact to activate the dome light circuit. It is also possible that the contacts of this switch are dirty or corroded.
    With the driver door closed, you can try testing the same switch on the passenger door to see if that one operates the circuit correctly. If so, you'll have to either clean or replace the switch(s). It appears that they are a pita to get to. You may have to remove the upper and lower B-Pillar panels. (I recently had removed the B-Pillar panel on my regular cab to do some wiring in that area and I had referred to a thread at TW explaining how to do this.)
    Here is the thread: http://www.tacomaworld.com/forum/2n...-dc-interior-head-liner-removal-write-up.html Look at the photos/instuctions under "Section 2 middle - Step 1 removal of B-pillar covers" (Located about halfway down in the thread.)
    Then again, you may be able to gain access to the switch by just removing the bolt below the rubber covering the switch (see photo). I don't know, since I haven't tried removing it that way.
    Beyond that, there may be a malfunction of the dimming circuit component. Unfortunately, I have no idea where that component is located or what's involved in replacing it.
    Good luck, and let us know your outcome!
  5. Feb 6, 2018 at 5:39 PM
    Tacorun2014
    Tacorun2014 Member
    2014 Toyota Tacoma prerunner
    Just watched a video, yes lift rubber bottom half, loosen bolt completely out, then pull out rest to find connection.
  6. Feb 6, 2018 at 6:49 PM
    Enokidaki
    Enokidaki Member
    Kevin
    14 dclb trd sport
    Yes, my truck has randomly left the lights on several times. Once stranding 5 of us on a kayaking trip. Nearest I can tell my door button doesnt always register the door as opened. Maybe this thread will inspire me to take this thing off and check it out!
  7. Feb 7, 2018 at 1:59 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    If the passenger door is opened first opening the drivers door will not turn off the headlights. A word to the wise.
  8. Feb 10, 2018 at 11:54 AM
    Tansisusan
    Tansisusan New Member
    I have had this problem since I bought my 2006 3 years ago. Headlights first, now also dome light. Then the ECM fried on the highway. No electrical. Suspected voltage surge or rogue cell in battery. Neither. Cannot risk another failed ECM at 120km/hr! So it is in the shop and a dedicated mechanic has the wiring schematic up and is walking through it line by line. They hooked up a couple of red lights that light up every time it comes to life and put a camera on it overnight. Sure enough, EVERY night the headlights come on - for anywhere from 15 mins to 7 hours. It is not the alternator/regulator nor the battery. I was ok with the idiosyncracies until the ECM fried on the highway.
    Open to all ideas and suggestions. Doesn’t seem that uncommon.
