problem with instrument cluster mod
Discussion in 'Lighting' started by RIDDICK3, Oct 9, 2011.
  1. Oct 9, 2011 at 9:45 PM
    RIDDICK3
    RIDDICK3 [OP] nuckin futs member
    Stefan
    Orem, Utah
    Icon, omd, lr uca, bed speakers, t-rex grill, 170 striker lights.
    Here is my problem, so I did the instrument cluster mod over the weekend and all the lights turn on great. but when I am driving my mph gauge will flicker a bit. when push in on the plastic it goes off and let go it turns back on. can anyone help me?
  2. Oct 9, 2011 at 9:51 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    You have a loose connection. Check all of your connections.
  3. Oct 10, 2011 at 7:02 PM
    RIDDICK3
    Stefan
    Orem, Utah
    I have twice and it still does it do you think that some of the leds are loose or somethin?
  4. Oct 10, 2011 at 7:03 PM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
    One of your LEDs in that cluster is loose the soder on one side is not making a good connection. Remove and redo them. I suggest holding them down when redo feeing them.
    Not the solder making a good connection one of the leeds is not.m if one does not work in a cluster they all won't.
  5. Oct 10, 2011 at 7:40 PM
    RIDDICK3
    Stefan
    Orem, Utah
    Really awesome I will give that a try, thanks for your input hope it works
  6. Oct 11, 2011 at 8:05 PM
    RIDDICK3
    Stefan
    Orem, Utah
    ok so I took them off and did them again and now they won't even turn on wtf am I doing wrong?
  7. Oct 13, 2011 at 8:59 AM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    Did u make sure theyre all facing the correct way(polarity wise) or if one isn't properly soldered on none will turn on
  8. Oct 13, 2011 at 7:51 PM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    16 Super White Limited 4x4
    if they were working intermittently and all you did is touch up the soldering then most likely you damaged a LED during soldering. LEDs can be pretty temperamental with heat. Do you have a digital meter by any chance?
  9. Oct 14, 2011 at 5:14 PM
    RIDDICK3
    Stefan
    Orem, Utah
    no I don't and i took them off and redid them with different led's and its still not working and now my rpms aren't working. and yes they are all facing the right direction.
    Sgeldert87 likes this.
  10. Feb 20, 2012 at 7:03 AM
    markmatters
    markmatters Viejon
    Mark
    Yuma, AZ
    2007 PreRunner
    I know this thread is old...but I ran into this problem and this might help someone in the future...i found out that these LED get fucked up easily if you leave the soldering tip (heat) for too long..i burnt like 15 of these when I did my swap. I was soldering all the LED's then going to the truck and connecting it..and hoping they would work...if one doesn't work in a certain area...none of them work..then I found this:
    You can test them before and after you solder them on...so if you fucked it up, test them...and leave the ones that work on...and replace the burnt ones...what worked for me was soldering them on quickly...no matter how they looked....let them cool for a few...and then adjust them quickly..hope this helps!
