Problem with interior lights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nburhans, Jan 2, 2016.
  1. Jan 2, 2016 at 7:36 PM
    nburhans
    nburhans [OP] Well-Known Member
    Nate
    Daytona Beach, FL
    2016 Tacoma SR5
    Does anyone know if the map lights, dome light and visor lights are on the same fuse? The owners manual was not to helpful on fuses. Anyway nothing happens when I press the map lights. Also nothing happens when I move the switch for the lights to turn on when the door is open. Also nothing happens when I flips open the visor. I'm guessing it's a fuse, but not sure do to all the interior lights not working.
  2. Jan 2, 2016 at 7:54 PM
    Stumpy29er
    Stumpy29er Well-Known Member
    2016Taco4x4TxEd
    I believe there is a 10 amp fuse under the dash that also feeds the interior lights.
  3. Jan 2, 2016 at 7:55 PM
    motomaster132003
    motomaster132003 Well-Known Member
    2016 Tacoma TRD OR DCSB
    Did you recently install LED interior lights?
  4. Jan 2, 2016 at 7:56 PM
    patr
    patr First-time Owner
    2016 Blazing Blue Pearl Tacoma TRD Sport 4x2
    Yes, you are correct they all use a single fuse
    Its to the left of the pedals, look up
    There is a little panel with all the fuses, their rating, and position
    The interior lights fuse is a 7.5 AMP rated one, if I remember
  5. Jan 2, 2016 at 7:56 PM
    patr
    Pretty sure it was a 7.5
  6. Jan 2, 2016 at 8:07 PM
    nburhans
    Nate
    Daytona Beach, FL
    2016 Tacoma SR5
    No mods to the interior at all. Not sure how a fuse could have blown. I have not even tried to use the map lights or any interior lighting until tonight. I will have to check in the morning and see if it's a fuse. Thanks
