Problem with lights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by johnny2154, Feb 6, 2013.
  1. Feb 6, 2013 at 2:50 PM
    johnny2154
    johnny2154 [OP] Well-Known Member
    Johnny
    Brewster, MA
    When I put the brakes on, the left blinkers blink and the blinker light on the dash stays solid, when i put the left blinker on the taillights flash, and the brake light over the cab flashes as well. Any ideas? ty
  2. Feb 6, 2013 at 2:54 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Any mods done lately?
  3. Feb 6, 2013 at 2:54 PM
    johnny2154
    Johnny
    Brewster, MA
    no nothing, about 1 1/2 years ago had a remote start installed!
  4. Feb 6, 2013 at 3:12 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    This all just started randomly? Do you have any practical jokers in your family or close friends that happen to be handy with wiring? Sounds like you have a short somewhere and the wires are rubbing unless you have done some wiring yourself recently like maybe added trailer wiring.
  5. Feb 6, 2013 at 3:16 PM
    johnny2154
    Johnny
    Brewster, MA
    Added a trailer hitch 3 yrs ago
  6. Feb 6, 2013 at 4:55 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    Did you change any bulbs recently?
    I had a similar thing happen to me when I was younger with my first car... I put the wrong bulb in. I think it was a 2 filiment brake and tail light into a single filiment socket or vice versa.
  7. Feb 6, 2013 at 6:24 PM
    johnny2154
    Johnny
    Brewster, MA
    haven't changed any bulbs
  8. Feb 6, 2013 at 6:28 PM
    johnny2154
    Johnny
    Brewster, MA
  9. Feb 6, 2013 at 6:40 PM
    river rat 69
    river rat 69 Well-Known Member
    Jim
    Orlando, Fla., Green side of the grass
    007, trd, sr5, fmf.
    NO Chrome,3" NFab's steps,TRD skid,Wet okie's.011 grill, k&n,5100's,All this comes right off when the old lady says let's go get a NEW ONE!!!
    Wild guess is its going to be something in the hitch harness.. Had 2 pals with crazy things happening to there pick up lights (1 ford,1 chev) both ended up being in the hitch harness. First place I would start looking. Sometimes the lil boxes to split the wires just go bad inside.
  10. Feb 6, 2013 at 6:47 PM
    johnny2154
    Johnny
    Brewster, MA
    i'll try that thanks
  11. Feb 6, 2013 at 7:37 PM
    Ryanv
    Ryanv Toyota Technician
    15 4Runner
    What year truck do you have? led brake lights? Check for bad ground in left tail circuit. If one fails it can back feed through other loads to find ground. Check for bad insulation in left tail lamp harness. Corrosion in light socket, bad bulb.
  12. Feb 7, 2013 at 3:30 AM
    johnny2154
    Johnny
    Brewster, MA
    07 tacoma
  13. Feb 7, 2013 at 5:42 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    When light do weird things it usually a bad ground some where.
  14. Feb 7, 2013 at 10:18 AM
    BamaToy1997
    Bill
    Navarre, FL
    Maineah beat me to it. I would check the grounds first to see if there are any that are loose or corroded. A voltage drop test would help with that. Also a faulty multifunction switch will do similar things as well. I will be happy to look up wiring information if you will post the information about your truck (Year, make, model, trans type, etc)
