Problem with my tacoma 2000.
Discussion in 'Performance and Tuning' started by west coast, May 24, 2007.
  1. May 24, 2007 at 6:30 PM
    west coast
    west coast [OP] New Member
    I Have A Problem With My Truck " Tacoma 2000 6 Cldrs " , When I Star It In The Morning It Turns On Fine But If I Turn It Off And Later On I Want To Turn It On Again, It Won't Star, I Have To Push The Gas, And Accelerate The Engine So It Won't Turn Off!
    I All Reday Took It To The Mechanic And The Run The Compuer But They Didn't Find Anything, I Also, Change The Start, The Battery, The Sparkplugs, The Oil,gas, And Air, Filters, I Have All Ready Waste A Lot Of Money Without A Result, So I Don't Know What Else To Do.
    Does Any One Has The Same Problem ?
    Can You Help Me To Find Out What's The Problem? Thakns In Advance . :)
  2. May 25, 2007 at 4:40 AM
    evolution6972
    evolution6972 Well-Known Member
    on my dads 1989 toy he had a cold start injector that caused that kinda problem one time
  3. May 25, 2007 at 1:38 PM
    twoarezee
    twoarezee Well-Known Member
    esco, ca
    00 Dropped Mini
    rims,tires,3"/6" drop, 4x4 front end, 01 tails and corners, prerunner buckets,tenzo r steering wheel w/ momo hub, b&m shifterw/ jdm trd knob, alpine system, tint, 3 3/4" autometer tach, jardine cat back, k&n, debaged, hellwig rear sway bar, kyb monomax shocks, tundra v8 oil filter w/ mobil 1 in ever
    check the throttle position sensor or the iac under the throttle body. my truck did the same thing for a little while. i cleaned the iac and throttle body and that fixed it.
  4. May 25, 2007 at 7:41 PM
    west coast
    Thanks I going to check the iac .:)
  5. Jan 28, 2015 at 7:39 PM
    fsbrain03
    fsbrain03 Well-Known Member
    Seems like you should not start and stop it so much. you may want to check electrical connections.
