Problem with Navigation
Discussion in 'Audio & Video' started by whiting1977, May 16, 2016.
  1. May 16, 2016 at 2:50 PM
    whiting1977
    whiting1977 [OP] Well-Known Member
    Sacramento CA
    2014 SR5 PreRunner
    I have had my Entune Premium in my 2014 for a year and a half and all has been well until recently. Within the last week or so the nav screen has become messed up. With destination programed and rolling along the right side of the screen is not working properly. When on the freeway and expecting to see the next 3 freeway exits on the right side of the screen or when on a surface street and using the turn by turn map mode and expecting to see the next 3 turns on the right side of the screen all I see is a blank screen saying "calculating". The only change to the system was a pushed update about 2 weeks ago. Did Toyota screw up my navigation?
  2. May 17, 2016 at 3:01 PM
    UBYBC
    UBYBC Well-Known Member
    2014 Tacoma TRD OR
    My update last week went ok on a 2015 Nav HU. Did you check sat antenna connection and that your SD card is seated in the slot well?
  3. May 18, 2016 at 12:51 PM
    whiting1977
    Sacramento CA
    2014 SR5 PreRunner
    I reseated the SD card. Not sure I want to check the sat antenna as that would require removing the HU wouldn't it?
  4. May 18, 2016 at 1:35 PM
    UBYBC
    2014 Tacoma TRD OR
    Yeah the antenna connects the back of the HU. HU removal is pretty simple just go slow so you don't crack or scuff the bezel. You'll need a socket extension also. There's a write up on removing the HU. I'm not sure it will help. You're issue is odd and it's really hard for the antenna to disconnect at the HU. I'd check the roof shark fin and/or the cable run to the HU. Maybe the nav unit crapped out. Either way the HU has to be removed to get back there.
  5. May 18, 2016 at 2:55 PM
    MudFlap
    MudFlap Well-Known Member
    Tim
    Memphis (north mississippi)
    2012 TRD Off Road
    I have a nav unit out of a 14 model, the one that was being sold like crazy here a year or 2 ago here. After that update 2 weeks ago or so, my unit has been screwing up. It started randomly rebooting while just listeningto the radio driving down the road. Done it 2 times in a 10 min drive the first time and the wind time it happened 4 times in my 30 min drive to work. I also noticed in between restarts, the general nav screen (just the map... not navigating) showed me way off the road and driving through rivers and stuff haha! It's been kinda irratating, I've been searching Google but havnt seen anyone recently with this same problem.
  6. May 18, 2016 at 5:45 PM
    spp
    spp OC, Kalifornia
    OC California
    I've had success holding the on / off down for a reboot and then putting the sd card in. Still experimenting with stuff that fixed it last week.
  7. May 18, 2016 at 5:53 PM
    UBYBC
    2014 Tacoma TRD OR
    All I can really add is my 2015 non JBL NAV HU took the update ok. And has been working alright .....:fingerscrossed:
  8. May 19, 2016 at 8:18 AM
    Revelations
    Revelations Well-Known Member
    2014 MGM DCSB
    Same problems for me, except the nav part. I don't use the nav enough to know if it's off.
  9. May 19, 2016 at 12:08 PM
    MudFlap
    Tim
    2012 TRD Off Road
    Well.... knock on wood.... mine has been acting ok for the last couple of days. It has only done the random reboots those two times and hasn't done it since. I'll still keep my eyes open for a fix, cause I know it's just a matter of time before it happens again.
  10. May 19, 2016 at 12:28 PM
    Revelations
    2014 MGM DCSB
    Mine is intermittent. Some days, it won't happen, some days it will happen frequently. My commute is 30-45 minutes each way. I think it's happened 3-4 times since the update.
  11. May 19, 2016 at 5:07 PM
    whiting1977
    Sacramento CA
    2014 SR5 PreRunner
    I spoke with Toyota Customer Service today. They were aware of issues since the update push a few weeks ago. They had me confirm my software version on the HU and said I needed a firmware update. I am to go to my Toyota Dealer and have them do it. The rep said the recent update causes issues with any firmware that is not the latest.
    MudFlap and Revelations like this.
