problem with the A/C in my truck
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ernesto4, Mar 16, 2015.
  1. Mar 16, 2015 at 3:58 PM
    Ernesto4
    Ernesto4 [OP] Well-Known Member
    North Hollywood
    15 Tacoma access cab 5 lug SR5
    i turn on the A/C and turn it all the way to the coldest setting and it blows just air. when i turn it to the hottest setting it does heat however.i recently got into a minor accident and the radiator did have to get replaced any idea what might be wrong or if its an easy fix i can do myself? thanks
  2. Mar 16, 2015 at 4:31 PM
    Joemama
    Joemama Well-Known Member
    Joe
    Utah
    2010 TRD Sport
    It could be a blend door issue which changes the flow of cold & hot air.
  3. Mar 16, 2015 at 5:12 PM
    charles08tacoma
    charles08tacoma Well-Known Member
    Santa Cruz, CA
    08 Prerunner SR-5 Access Cab
    White Snug Top shell
    About 10 years ago I had a 97 Tacoma with a similar problem after an accident. The body shop disconnected my ac lines when they put it on the frame rack to make sure everything was aligned. After many trips back to the body shop, it was found the cheap bastards didn't put o-rings back in the connectors & had a big leak there. Finally got it fixed.
  4. Mar 16, 2015 at 5:18 PM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    If they pulled the AC condenser to replace the radiator, they may have forgot to recharge the freon. Another possibility is the ac fuse in the under hood fuse block next to the battery. Several times with my 2008 Taco, when I replaced the battery, my ac compressor would not kick on. I just replaced the fuse and everything worked great. BTW, the old fuses never looked burned, but the new fuses solved the issue. Don't know why.
  5. Mar 16, 2015 at 8:52 PM
    Ernesto4
    North Hollywood
    thank you very much! i was thinking it was probably the freon as well since everything else seems to be working properly and i dont hear any weird noises when i start my a/c up it just doesnt blow cold air. however now that you mentioned it i will definitely check the fuses.
  6. Mar 16, 2015 at 8:55 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The accident that damaged the radiator also damaged the AC Condenser and you have lost the refrigerant. They are right up there together. The Compressor clutch is probably not engaging either due to the low refrigerant pressure.
    Take it to a shop that does AC work and have them check the refrigerant charge.
  7. Apr 9, 2015 at 4:23 PM
    Whitetaco10
    Whitetaco10 Member
    St. Petersburg, FL
    2010 White Tacoma SR5 V6
    3" level lift
    I agree, I am an AC tech but not for cars, they all work the same. If you had damage to the radiator you must have had damage to the condenser. Go check it out
