Problem!!
Discussion in 'Lighting' started by branct06, Jul 19, 2010.
  1. Jul 19, 2010 at 9:12 PM
    branct06
    branct06 [OP] Well-Known Member
    Thomas
    norcross Ga. and High Point Nc.
    05 4x4 black sr5 long bed trd sport
    super 40 flowmaster turned down before rear axle, k&n intake, ipod interface, 20% 3m tint all the way around, grill craft mx series grill with 2 hella 500 behind the grill, 2 55 watt halogens mounted on uws black low profile toolbox, 3'' toytec ultimate lift kit sitting on black xd monsters and 285/65/18 BFG A/T, HID headlight kit
    I have an HID kit in my truck and sometimes the right headlight doesnt turn on and sometimes it does?????? I have switched out ballists and everything.... any ideas on what the issue is?
  2. Jul 19, 2010 at 10:17 PM
    Trap
    Trap Well-Known Member
    Indego Ink TRD OR
    Electric Tail Gate Lock, EZ Down + Cable Mod, Galvanized Underbody, DK 9000, CloudRider SS Grill insert. BakFlip HD, Cabin Air Filter mod, Alarm, Zero Rust !
    Bad connection, simple as that. check all the crimps. If you soldered check all the joints for a cold solder. Got to be power. Bad ground even.
  3. Jul 19, 2010 at 10:26 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    my gues is a bad ground. mine worked great for a couple weeks, then all of the sudden the passenger side went out...turns out it was just a bad ground. i found a better ground and they've been perfect ever since
  4. Jul 19, 2010 at 10:36 PM
    Trap
    Indego Ink TRD OR
  5. Jul 20, 2010 at 1:41 PM
    branct06
    Thomas
    I have checked the ground even hooked it to the battery as a ground just to see if that was the problem and the same thing happens
  6. Jul 20, 2010 at 1:53 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    might be a loose connection internally then
