Problems after doing clutch job, 2000 2wd
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Yosuthnmasa, Jan 3, 2014.
  1. Jan 3, 2014 at 10:35 AM
    Yosuthnmasa
    Yosuthnmasa [OP] New Member
    Georgia
    2000 2wd Single Cab
    Just did a preventative clutch job on 2000 2wd with about 200,000 miles. Replaced clutch assembly, pilot bearing, throwout bearing, and had flywheel turned. Didn't touch the slave or master cylinder or break any lines loose. Before starting it up, I noticed the transmission goes into all gear now without the clutch being pushed in. Ideas? Hate to crank it with it in gear already and clutch out. Slave cylinder is pushing the throwout bearing fork.
  2. Jan 3, 2014 at 10:37 AM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    Won't hurt anything if it will slide into gear with the clutch out and not running. push clutch and knock it in neutral and bump it over a couple times. If everything sounds okay crank it. Then try to put it in gear easily. If you are worried it might grab and take off pull the ebrake. Also this should be in 1st gen section not 2nd gen.
  3. Jan 3, 2014 at 10:55 AM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Did you remove the shift tower from the transmission at the 4 bolt flange? If yes, does the shifter feel normal in that all gear positions hold in their detents as normal? If so, start it up, and give it a go. If it feels "off", pull the shift tower again, and see whats gone wrong.
  4. Jan 3, 2014 at 12:01 PM
    2000GTacoma
    Snow Hill NC
    Shouldn't have had to unbolt anything. The shifters will come out without being unbolted. At least on my 2000 3.4l 5sp they did. Push the ring down turn it a quarter turn and pull up.
  5. Jan 3, 2014 at 12:35 PM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    I am not trying to be smart, but are you sure you did not put the clutch plate in backwards?
