Problems after I replaced my AC Evap Core, Heater Core, Expansion Valve, and Condenser change
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sfcmcmahon, Jun 16, 2023.
  1. Jun 23, 2023 at 2:36 PM
    Sfcmcmahon
    Sfcmcmahon [OP] Well-Known Member
    Central Florida
    2013 Tacoma TRD Sport 4x4
    I noticed it while I was at highway speed.
  2. Jun 23, 2023 at 2:43 PM
    Sfcmcmahon
    Central Florida
    Could it be the fan clutch or water pump?
  3. Jun 23, 2023 at 2:45 PM
    Pittsy
    Pittsy Ex car guy, currently in rehab
    Davis
    Cave Creek, AZ
    07 DCSB 4x4, 20 DCSB PRO 6MT
    BTF Fab +4.5 - DMZ SUA - TE Cage - LS6 Swap
    At highway speeds a fan clutch wouldn’t matter I don’t think. Nor would a water pump
    If you weren’t using the heat at all. Did you start overheating?
  4. Jun 23, 2023 at 2:50 PM
    Sfcmcmahon
    Central Florida
    No overheating so that makes sense. Well, any suggestions?
  5. Jun 23, 2023 at 2:52 PM
    Pittsy
    Davis
    Cave Creek, AZ
    Only thing I could chalk it up to is a contaminant in the refrigerant system. Moisture or air, or something that isn't r134a.
  6. Jun 23, 2023 at 2:59 PM
    Sfcmcmahon
    Central Florida
    It was professionally vacuumed and recharged. Hopefully that's not the problem.
  7. Jun 23, 2023 at 4:28 PM
    Sfcmcmahon
    Central Florida
    I'm convinced the re-circulation isn't engaging. Normally when I press the re-circ button I hear more airflow. I'm sure that's because a vent that sucks the air in from the outside closes and pulls air from inside only. Perhaps that vent isn't closing? Maybe I failed to hook something up, or screwed something up.
  8. Jun 23, 2023 at 4:50 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Pop the glovebox out and check blend door operation.
    https://www.tacomaworld.com/threads/2nd-gen-information-diagnostics.784008/#post-28042158
  9. Jun 23, 2023 at 5:03 PM
    Sfcmcmahon
    Central Florida
  10. Jun 23, 2023 at 6:24 PM
    RockfordTaco2006
    RockfordTaco2006 Well-Known Member
    Alexander
    2006 Toyota Tacoma TRD Off Road 4x4
    2 Inch Lift
    I still haven't checked my HVAC since I re-installed mine. It's on my list of things to do. One things I did when I re-assembled my HVAC box and lined the pulleys up was to put a little bit of White Lithium Grease in the tracks. I've got my fingers crossed you get yours figured out.
    Sfcmcmahon[OP] likes this.
  11. Jun 24, 2023 at 5:30 AM
    Sfcmcmahon
    Central Florida
    I didn't even think about that. I'll find a way to get some in there. Thanks for that!
