Problems after putting the truck in 4x4
Discussion in '2nd Gen. Tacomas (2005-2015)' started by conorsimpson69, Nov 23, 2008.
  1. Nov 23, 2008 at 6:45 PM
    conorsimpson69
    conorsimpson69 [OP] New Member
    08 tacoma
    After driving my 2008 tacoma on a bumpy, snowy dirt road and after putting it in 4x4 for probably the first time the truck has completely f'd up on me.
    The low tire pressure light is on and it stays on even though the tires are inflated to 40psi, but it was doing that before the truck went into 4x4. The 4wd light on the dash won't go off and the 4low light flashes and beeps even though the dial is in 2wd. The steering begins to get jerky when the wheels are turned sharply, even when they aren't turned all the way. When starting to move, the truck acts like the tires are slipping like it's on ice and jerks forward even on dry pavement. When driving above about 30 km/h with the engine above 2000rpm I start to hear a whirring noise which becomes much louder as the speed increases. This noise doesn't happen if the truck is coasting in neutral at speed or when the engine is revved with the truck stopped in park/neutral.
    Anybody else experience similar problems with their trucks? I'll be bringing the truck in this week for service but any information beforehand would be appreciated.Thanks.
  2. Nov 23, 2008 at 6:47 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Sounds to me like your truck is stuck in 4hi or low.
  3. Nov 23, 2008 at 6:50 PM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    Chris4x4 is the right guy to take advice from. His credentials are good on problems.
  4. Nov 23, 2008 at 6:50 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yep....i agree!! and be sure to check the spare tire also...........it has a sensor too!
    welcome to tw!
  5. Nov 23, 2008 at 6:52 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Thanks! I have been wrong many times, though. Trying to diagnose a problem online without being able to hear, see, feel, smell, etc. is a bit chalenging. :)
  6. Nov 23, 2008 at 6:58 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    The whirring is the transfer case- the truck is in 4low, its completely normal when in low. the tire pressure light is probably due to the spare being low as others have said. to get the truck out of 4low stop, put the transmission in neutral with your foot on the brake and turn the dial to 4hi. then put it back in gear after you hear a click or clunk or after the 4-low light goes out. then creep forward a little and turn the dial back to 2hi and it should come out of 4wd
  7. Nov 23, 2008 at 8:17 PM
    Johnson8537
    Johnson8537 Well-Known Member
    Oregon
    06 TRD SPORT 4x4 Double Cab Long bed
    Revtek Leveling Kit with 1 1/2 block spacer in rear. 17" MotoMetal blacks on 32" tires. Access Lorado Tonneau - Bed mat Billet Grill Tinted Windows Pioneer 700BT with PAC steering wheel inerface. Wet Okole Seat Covers Front and back.
    my 05 AC cab did this once...
    I had to put the truck in gear.. (6 sp) shut off the truck.
    then turn the truck to 4hi start the truck move it a bit..
    then turn it to 2wd move a bit... Then it kicked out of 4wd.
    I hope this helps
  8. Nov 23, 2008 at 8:41 PM
    CJH9980
    CJH9980 Well-Known Member
    Clint
    Shreveport, LA/Tucson AZ
    2018 TRD PRO
    Wescott lift Wescott rock sliders Prinsu Cabrack SpartanXcustoms skewp light Demon Hook front recovery point Diamondback SD (just shipped) N2 Designs Remote Start A few meso goodies
    Didnt know that! thats probably why my light is on...
  9. Nov 23, 2008 at 8:42 PM
    conorsimpson69
    08 tacoma
    Wow, thank you all for the quick responses! I tried what Johnson8537 suggested an it worked perfectly. The low tire pressure light is still on, but that is probably just the spare tire.
  10. Nov 24, 2008 at 7:06 AM
    longbow
    longbow I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    man I learned something new, don't have the issue, but that is GREAT info to know.
    OH yes......welcome to TW
  11. Nov 25, 2008 at 10:14 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Just a question and not trying to be a jackass. (This time anyways)
    Does anyone read the manual?
  12. Nov 26, 2008 at 2:33 PM
    javajunk-e
    javajunk-e Well-Known Member
    So. Cal
    '09, Super White, DCLB, 4x4, Sport.
    Tacoma all weather floor mats, N-Fab Prerunner light bar w/ Hella 500ff lights, mag-lite mod, Hi-lift jack, Wet Okole seat covers, Revenge Fab sliders, ARE MX shell with Thule racks, and a Bed Rug.
    You would think after spending your hard earned money that people would pick up the manual and read some of the important stuff. However this site has a plethora of information and in most cases is better than the manual.:D
  13. Nov 26, 2008 at 2:46 PM
    RedTaco2134
    RedTaco2134 Well-Known Member
    Scott
    Portland, Or
    08 Long Bed TRD Sport
    295/70/17 Cooper STT Pro, Revtek 3" lift. TSB rear and Blistein 5100's http://www.cardomain.com/ride/3097063
    Have you tried reversing, like 10 feet or so? usually un-binds anything with the T-case. It should almost always "kick-out of 4wd" after reversing.
  14. Nov 26, 2008 at 2:56 PM
    Johnson8537
    Oregon
    I tried that with mine as well... and the only thing that worked was the process i posted above.
  15. Nov 26, 2008 at 3:25 PM
    wushaw
    wushaw Well-Known Member
    Texas
    08 AC TRD 4x4 6sp
    Just another reason to have a manual x-fer case...no mickey mouse BS.
    Comming from learning on my Jeep, I had a little difficulity learning how mine worked also, cause when you start plugging wires into what once was a very simple & reliable device (handle), things tend to not act like they once did.
  16. Nov 26, 2008 at 3:32 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    X2
  17. Nov 26, 2008 at 3:33 PM
    jrws6
    jrws6 Well-Known Member
    Western North Carolina
    07, Dodge Ram 35004x4 Cummins Turbo Diesel 6M
    X2
    BUMP
    I have heard manual hubs improve mpg slightly also versus this push button set up.
