Problems after replacing battery
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mjc 4452, Feb 12, 2018.
  1. Feb 12, 2018 at 2:55 PM
    Mjc 4452
    Mjc 4452 [OP] New Member
    i have a 2007 Tacoma with a 2.7 4 cylinder. It is a manual. I replaced my battery today and afterwords my truck started running rough. While idling I could turn the wheel or mash the clutch and the truck would nearly cut off. I finally got to where I was headed and about three hours later I went to crank it and it would start but only run for a few seconds. Eventually it cranked and ran rough again but is starting to seem like it has began to run better. Has anyone ever had this issue? If so what was the problem? Thanks!!
  2. Feb 12, 2018 at 3:11 PM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Computer needs time to relearn
    Welcome to TW
    TACOVRD likes this.
  3. Feb 12, 2018 at 3:16 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    This
    TACOVRD likes this.
  4. Feb 12, 2018 at 3:23 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Yup..... should be back to normal in a day or two
  5. Feb 12, 2018 at 3:25 PM
    SirRoytzz
    SirRoytzz Taco Enthusiast
    When changing the battery on newer Toyotas (from what I understand) the car needs about 30 minutes to adjust. You need to drive it around and let it do its thing. The RPMs will be all over the place.
  6. Feb 12, 2018 at 4:19 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Clean the throttle body
