Problems - Code PO456
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12Tac, May 19, 2012.
  1. May 19, 2012 at 5:21 PM
    12Tac
    12Tac [OP] Well-Known Member
    Colorado
    2020 Double Cab, Long-bed TRD Off Road.
    SnugTop, FN Wheels, Meso Custom, Tacos4Cheap
    Hey folks...
    Got a check engine light with the "Trac off" light this afternoon. Put my code tracker on it and got a PO456. When I turn the truck off I hear a hissing in the engine compartment as though its releasing pressure on something. Truck has less than 2400 miles on it. Called the dealer - in on Monday.
    Any idea? Fuel system leak, O2 sensor, gas cap?
    12Tac
  2. May 19, 2012 at 5:43 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    • A small leak in any of the EVAP hoses or fuel tank hoses
    • A small leak in the purge valve or vent valve
    • The EVAP Canister may be leaking
  3. May 19, 2012 at 6:53 PM
    12Tac
    Colorado
    Well whatever it is I'm not happy its happened this early or soon with the truck. Its just a few months old for cry'n out loud.
    12Tac
  4. May 19, 2012 at 6:56 PM
    Wile
    Wile Well-Known Member
    Tim
    New Mexico
    08 4x4 DC TRD Offroad
    Pioneer AVH-5600BHS, ScanGauge, Wet Okole Seat Covers, Allpro Aluminum front bumper, Allpro Aluminum IFS skid plate, Allpro APEX rocksliders, Warn 9500s winch
    Would you prefer it happen later when you are out of warranty? I say work all the bugs out now or pay for them later.
  5. May 19, 2012 at 6:58 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Probably something real simple like a gas cap. Dont get mad or sad yet.
  6. May 19, 2012 at 7:19 PM
    12Tac
    Colorado
    Tim & Surgie,
    Agree and agreed. I would obviously prefer to have this happen now under warranty. Sad, no...upset...slightly. Its a new truck!
    Its all relative.
    12Tac
  7. May 19, 2012 at 7:24 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Still it should not have happen. Tacoma quality definetely suffered since 2009. :confused:
    Its hard to defend things like that.
  8. May 23, 2012 at 7:50 PM
    12Tac
    Colorado
    Okay...so here is what the dealer found out about the PO456 code...
    Dropped the truck off at the dealer...said it would be about an hour before they knew anything...56 minutes later I was told they had no idea what the problem was...'something with the fuel system...need more time.' Great...I said I'd wait. About 30 minutes later the service guy says they need more time...'techs here have no idea and we need to contact Toyota.' So I get a lift back to work. About two hours later I get a call. "Truck is ready for pick up." I get to the dealer and was told it was the gas cap. Apparently it was loose and caused all the ODI-II code. They reset the code and sent me on my way.
    So far I've not had any issues, but I find it interesting and puzzling that their techs didn't figure that out...or they simply got stumped, reset the code and 'get the customer out the door.'
    12Tac
