Problems Continue... Neutral Safety Switch
Discussion in '2nd Gen. Tacomas (2005-2015)' started by phillipthetaco, Jan 4, 2017.
  1. Jan 4, 2017 at 1:19 PM
    phillipthetaco
    phillipthetaco [OP] Well-Known Member
    Marcus
    Mesa,AZ
    2007 Tacoma Prerunner Barcelona Red
    Wheels and Tires: (5) 35/12.50/17 Toyo R/T tires (5) 17” x 8.5” Matte Black Method NV wheels Black extra thread (ET) spline lug nuts Front Suspension: Total Chaos 3.5” long travel kit Fox 8” x 2.5” coilovers with remote reservoirs Wheelers Super Bumps Limit straps and clevis mounts Total Chaos shock tower gussets Total Chaos cam-tab gussets Maxtrac 4 inch lift spindle Larger Lexus rotors, calipers and brake pads Stainless steel extended brake lines Rear Suspension: DMZ Fabrication Spring Under Kit Fox 16” x 2.5” smooth body shocks with remote reservoirs Fox 4” x 2.0” hydraulic bump stops (shortened to 3”) Custom low profile bolt in bed cage (1.5” DOM tubing) Boxed frame from fuel tank back Custom tube rear cross-member (1.5” DOM tubing) Custom bump stop mounts and strike pads Stainless steel extended brake lines Performance: AFE cold air intake w/reusable filter Nitro 4.88 Gears w/heady duty seals Custom driveshaft with grease-able slip-yolk Odyssey Extreme battery Armor: Custom front tube front bumper (1.5” DOM tubing) w/custom skid plates and valance Custom rear tube bumper w/license plate mount and led light Exterior Accessories/Body: SDHQ “y-strap” for spare tire mounting Harbor Freight 1.5 ton floor jack w/quick release mount Fiberwerx fiberglass front fenders Fiberwerx fiberglass “TT” style bedsides Custom window tint and tint visor Retrofit style Headlights LED tail lights Custom black mesh grill Viper alarm Rigid Industries 30 inch amber LED Rigid Industries 20 inch white LED Rigid Industries D2 Blue rear chase lights X2 Interior: Pioneer touch screen head unit Kenwood mono amplifier Rockford Fosgate 12" P3 subwoofer Infinity Kappa door speakers (4) Weathertech front floor mats LED interior dome lights
    SOOO... long story short. Was offroading one night and my Check engine light came on (codeP0705) as well as My reverse Indicator on my display when I was in Drive. So it's telling me I'm in Drive and Reverse at the same time (backup camera came on as well). Well, no matter what gear I am in (drive, neutral, park) my reverse indicator is always on as well as my backup camera. Many people told me it is the Neutral Safety Switch. I went out and bought one and replaced my old one. Well the Check Engine Light is still on as well as my Reverse Indicator always being on as well as my back up camera. Am i missing a step or is there a certain way to reset the Neutral Safety Switch?? I tried erasing the Code with my OBD scanner but no luck. Any help/advice will be greatly appreciated!
  2. Jan 4, 2017 at 4:28 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Is this what you replaced:
    If yes and you still have the same issue, then it is probably a wiring problem.
    phillipthetaco[OP] likes this.
  3. Jan 4, 2017 at 4:31 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    More information on that code:
    P0705 Transmission Range Sensor Circuit Malfunction (PRNDL Input)
    DTC Detection Conditions:
    Either of the following conditions is met:
    (a) Any 2 or more of the following signals are ON simultaneously. (2-trip detection logic)
    • Park/neutral position switch input signal is ON
    • R input signal is ON
    • D input signal is ON
    • 2 input signal is ON
    (b) Any 2 or more of the following signals are ON simultaneously. (2-trip detection logic)
    • 3 input signal is ON
    • L input signal is ON
    Trouble Areas:
    • Open or short in park/neutral position switch circuit
    • ECM
  4. Jan 4, 2017 at 4:32 PM
    phillipthetaco
    Marcus
    Mesa,AZ
    I wonder where in the wiring it would be??
  5. Jan 4, 2017 at 4:34 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Between that switch assembly and the ECU...
  6. Jan 4, 2017 at 4:36 PM
    phillipthetaco
    Marcus
    Mesa,AZ
    My buddy and I will check it out tonight. I'll reply back on here with what I learned. Thank you my man!
  7. Jan 4, 2017 at 4:43 PM
    Bocsy44
    Bocsy44 Well-Known Member
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    This that and the other thing.
  8. Jan 15, 2018 at 11:06 AM
    Jon G
    Jon G Hoarding Tacomas one at a time,
    Jon
    St John's Newfoundland Canada
    02, 04 & 07 Tacoma
    Magnaflow 2.5 Catback Exhaust K&N filter
    Any luck with this ?
  9. Jan 15, 2018 at 7:59 PM
    phillipthetaco
    Marcus
    Mesa,AZ
    Man oh man that was a while ago lol i dont even have the truck anymore but in the process of a new one. Last thing i remember was a mechanic said there was a short with the back up camera itself so when the backup camera came on randomly without being in reverse, the truck thought it was in reverse with the gear illumination lol. Didnt affect the way it drove so i just disabled the back up camera
    Jon G[QUOTED] likes this.
