Problems pouring gas from 5 gallon jerry can with overhanging truck camper
Discussion in '2nd Gen. Tacomas (2005-2015)' started by billthehiker, Sep 8, 2020.
  1. Sep 8, 2020 at 1:12 PM
    billthehiker
    billthehiker [OP] Well-Known Member
    Camper prevents me from tilting the can high enough to get all the gas out. What is worse it also makes it very awkward to operate the CARB compliant spout so I end up spilling gas all over. It is the metal can from Midwest Can.
    Is there an easy pour spout that will fit CARB compliant cans, or an adaptor?
    Or maybe a very large and very long funnel which I can't find so far?
    Already invested a lot of time doing a custom mount on the back of the camper and really do not want to go with a different gas can.
    Gunshot-6A likes this.
  2. Sep 8, 2020 at 1:17 PM
    WoodsGhost
    WoodsGhost Well-Known Member
    PA
    2017 DCSB OR:2016 4Runner
  3. Sep 8, 2020 at 1:19 PM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    There are adaptors, but I dont know of any for that style with the screw on spigot if its the 5 gal metal ones. The good news is something like the NATO or Wavian cans of the generally same design do, and they may be close enough that your mounts will fit them.
  4. Sep 8, 2020 at 1:21 PM
    FFBlack
    FFBlack Well-Known Member
    2019 TRD OFF ROAD
    Get a racing gas can with a long filler hose, no govt BS valves or anything.
  5. Sep 8, 2020 at 1:44 PM
    JohnT43
    JohnT43 Well-Known Member
    2007 Tacoma
    Radio
    Harbor freight jiggle hose.
  6. Sep 8, 2020 at 1:47 PM
    Shellshock
    Iowa
  7. Sep 8, 2020 at 1:47 PM
    Lastplace
    Lastplace Well-Known Member
    Southeast VA
  8. Sep 8, 2020 at 2:48 PM
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    Another vote for the jiggle siphons, they work really well.
  9. Sep 8, 2020 at 3:01 PM
    billthehiker
    Does the jerry can need to be higher than the truck fuel tank for the siphon to work?
  10. Sep 8, 2020 at 3:03 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Use a funnel.
  11. Sep 8, 2020 at 3:10 PM
    BKinzey
    Beauford
    Hollywierd, CA
    Pretty much yes. I'd bungie or tie it to the camper. The first time I used mine I held the can, didn't take too long. The second time I parked next to a picnic bench. :thumbsup:
  12. Sep 8, 2020 at 3:18 PM
    billthehiker
    the siphon seems like my best bet. It is compact and easy to store in the space between camper wall and truck bed so no gas fumes get inside. I have a camp table and step stool to elevate the gas can if necessary.
  13. Sep 8, 2020 at 3:42 PM
    Taco-Grinder
    Dan
    Fond du Lac, WI
