Problems raising/lifting seats!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rob4092xx, Aug 4, 2017.
  1. Aug 4, 2017 at 5:52 PM
    rob4092xx
    rob4092xx [OP] Well-Known Member
    Phoenix, AZ
    I went and tried to raise my 2017 Taco seats with washers and longer bolts. Couldn't get them to line up. Seems like as I raised the seat with washers, the alignment became off making it impossible to get the bolts in. Advice please??? Thanks all!
  2. Aug 4, 2017 at 6:49 PM
    Paterico
    Paterico Well-Known Member
    San Antonio, TX
    2017 DCSB TRD OR 4x4
    My advice is to leave the fasteners the way that they were and find a seat cushion to raise you up.
    Stacking washers in a crucial application like that is not safe.
  3. Aug 4, 2017 at 6:55 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Or, if you insist on doing this....the spacer must be angled. I'm thinking a piece of pipe of the appropriate dia. and then cut on an angle that move the rear higher than the front.....
    Just something I'd look at doing if I were so inclined...
    Good luck... Made sure you get longer and stronger bolts.....!!!
    Kilokato and JoeCOVA like this.
  4. Aug 4, 2017 at 6:58 PM
    TRD493
    TRD493 Well-Known Member
    Dave
    Texas (DFW)
    17 TRD Sport DCLB 4x4 / 01 4x4 V6 Extra Cab TRD SR5
    There's a couple of threads on it in here if you search for them. I believe you can only raise the back of the seat. The way the front brackets are angled would prevent you from raising it as well. I haven't see a solution on here yet for the front.
  5. Aug 4, 2017 at 10:33 PM
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    I have the opposite problem. Yours is easy
    asc, TacoFister, kgilly and 4 others like this.
  6. Aug 5, 2017 at 12:13 AM
    AWDDude
    AWDDude Well-Known Member
    2017 Tacoma TRD Off Road DCSB, QuickSand
    yeah i wish i could lower the front seats
  7. Aug 5, 2017 at 6:29 AM
    harrycary
    harrycary Well-Known Member
    Harry
    2016 Tacoma TRD Off Road
    How much higher are you wanting to go?
  8. Aug 5, 2017 at 6:32 AM
    Frankenstuff
    Frankenstuff Busy iracing
    Frankie
    16TRDORDCsb 4x4 & 2020 BMW M2 competition
    16 trd ORdcsb4x4 c4 swingout rear, cbi t3 front , arb lift,16"grabber x3 rtt, hilift,jerry cans,and sliders . 81 hilux trail donkey
    Uhhh what are we talking about here?
  9. Aug 5, 2017 at 6:33 AM
    harrycary
    Harry
    We are talking about raising a seat height, right?
  10. Aug 5, 2017 at 6:34 AM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    I'm guessing OP is really, really short?
    harrycary[QUOTED] likes this.
  11. Aug 5, 2017 at 6:43 AM
    Frankenstuff
    Frankie
    Me too... Or the hood is really tall.
  12. Aug 5, 2017 at 6:58 AM
    rob4092xx
    Phoenix, AZ
    1/2 inch or so.
  13. Aug 5, 2017 at 7:00 AM
    harrycary
    Harry
    I think you will need to have brackets fabricated. Be sure to use good material and grade 8 bolts. Your seat is a safety device.
  14. Aug 5, 2017 at 7:02 AM
    DrFunker
    DrFunker Well-Known Member
  15. Aug 5, 2017 at 7:11 AM
    LJGIbbs
    LJGIbbs Well-Known Member
    Independence Missouri
    2017 TRD PRO Cement 6MT
    none yet/none planned! It's perfect!
    You know in a crash the seat does nothing for you! The seat belt does all the work!
  16. Aug 5, 2017 at 7:13 AM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Not safe and may cause problems if ever injured in an accident with insurance...if you are found to have tampered with engineered safety equipment...
    Garrett75x likes this.
  17. Aug 5, 2017 at 7:13 AM
    smitty99
    Scottsdale
    Totally false.
  18. Aug 5, 2017 at 7:22 AM
    LJGIbbs
    Link?
  19. Aug 5, 2017 at 7:29 AM
    harrycary
    Harry
    Very true.
  20. Aug 5, 2017 at 7:42 AM
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    Just raise the rear--I made 32 mm long spacers of 1¼ aluminum bar stock. Used M10 x 1.25 x 60 class 10.9 flange head bolts and hardened washers from Ace Hardware. Metric class 10.9 fasteners have a tensile strength of approximately 10 * 100 = 1000 MPa (145k PSI), and a yield strength of 90% of that. They are the equivalent of SAE grade 8 fasteners--torque them to 27 lb·ft.
    Done in this manner I have no concerns as to the safety of the modification.
    The OEM bolts have an M8 x 1.25 tapered nose, I suspect as an assembly aid. I turned down the nose of the M10 bolts which made getting them located and started much easier.
