Problems raising/lifting seats!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rob4092xx, Aug 4, 2017.
  1. Aug 5, 2017 at 7:45 AM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    Functional hood scoop mod...
    mikestaco17 likes this.
  2. Aug 5, 2017 at 7:52 AM
    Frankenstuff
    Frankenstuff Busy iracing
    Frankie
    16TRDORDCsb 4x4 & 2020 BMW M2 competition
    16 trd ORdcsb4x4 c4 swingout rear, cbi t3 front , arb lift,16"grabber x3 rtt, hilift,jerry cans,and sliders . 81 hilux trail donkey
    Nice . Almost beyond functional. If there was such a thing as to much power.
    Kyitty[QUOTED] likes this.
  3. Aug 5, 2017 at 7:54 AM
    dsixnero
    dsixnero Well-Known Member
    Dan
    2016 Tacoma TRD Off Road White
    None yet
    If you raise the seats, how will you get your legs past the steering wheel?
  4. Aug 5, 2017 at 7:55 AM
    Frankenstuff
    Frankie
    Raise it in the rear only ?
  5. Aug 5, 2017 at 8:07 AM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
  6. Aug 5, 2017 at 8:25 AM
    chrisrocks300
    chrisrocks300 War Eagle
    Brandon, MS
    2016 4x4 Tacoma DCSB Trd Off-road Superwhite
    Total Chaos UCA's, Raceline Raptor wheels (16x8) 4.5 BS, 285/75/16 Cooper S/T Maxx tires, Icon Stage 2 Lift Kit, Sos sliders w/ fill plates, exhaust reroute, mobtown offroad skid plates (ifs, transmission, transfer case), and diff breather mod
  7. Aug 5, 2017 at 8:27 AM
    chrisrocks300
    Brandon, MS
    Also if you raise the seat I can tell you that you'll hit your head on the roof. Unless you like 5'5" :notsure:
  8. Aug 5, 2017 at 8:37 AM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    OP you can only change the angle of the seat by raising the rear with spacers. To raise the whole seat would require further more elaborate seat frame modification, and that may affect the re-sale value and possibly cause safety concerns if not done properly.
    You can however go to an upholstery shop and get better fitting seat cushion but that can also affect re-sale value and cost as its more permanent.
    It may be best to get a memory seat cushion from Walmart or Amazon:
    https://www.amazon.com/Relaxzen-60-...?s=automotive&ie=UTF8&qid=1501946117&sr=1-151
    I would just make sure its the wider type with a strap on the rear that you can attach with landscape tape. It works like Velcro tape but it can be more easily removed when needed.
    I got one for my wife to use on the 4Runner as the leather seats are stiff, not soft like our Taco and she loves it. Cost $25, they have cheaper ones, but not worth it imo
    Hope that helps
    Cheers!
  9. Aug 5, 2017 at 8:43 AM
    rob4092xx
    rob4092xx [OP] Well-Known Member
    Phoenix, AZ
    Did you do the front seats????
  10. Aug 5, 2017 at 9:29 AM
    smitty99
    Scottsdale
    If you aren't an engineer qualified to make these design changes to vital safety equipment you should proceed at your own risk.
    9th likes this.
  11. Aug 5, 2017 at 12:12 PM
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    No, just the rear, that raise your body by whatever length the spacers are. The seat bottom was tilted too much toward the rear for my taste to begin with--it had a "deep dish" sort of ghetto seating position...
  12. Aug 5, 2017 at 12:26 PM
    cliffyk
    Cliff
    Saint Augustine, FL
    I am 5'9" and there remains at least 5 inches of headroom with the 32 mm spacers--plenty for me and my Panama hat:
  13. Aug 5, 2017 at 12:27 PM
    chrisrocks300
    Brandon, MS
    Oh my bad didn't realize you were a second gen
    Edit: wait you aren't the op, the third gens have lower head room
  14. Aug 5, 2017 at 12:29 PM
    Garrett75x
    Garrett75x Well-Known Member
    Torrance
    2017 TRDOR 4x4 JBL P&T
    Pro Grille, Shmellfab rock sliders, Carhartt seat covers
    Wait so there are people that need the seat higher? :eek:
    pra4sno and chrisrocks300 like this.
  15. Aug 5, 2017 at 12:31 PM
    #35
    cliffyk
    Cliff
    Saint Augustine, FL
    This is so, there was a recent post where a fellow wanted to use polyurethane spacers--using a stack of washers would be better, not at all recommended but better than polyurethane...
  16. Aug 5, 2017 at 12:35 PM
    #36
    cliffyk
    Cliff
    Saint Augustine, FL
    Huh, didn't know that--probably to gain another 0.002 MPG
  17. Aug 5, 2017 at 1:04 PM
    #37
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    the seat is designed to be bolted against a flat surface. When you raise it up with a spacer or washer the seat frame no longer has that support and your putting a lot more force on the bolt itself. Even using a hardened steel high grade bolt still my be unsafe. I'm no engineer, but I can tell you you're increasing the stress on the bolt and it could sheer due to the impact of a collision. Imagine getting T-boned or clipped at an intersection and your truck going into a spin. That's a lot of force. Now imagine those bolts sheering and you are now a projectile inside your vehicle. You're going to be throw and whipped around like a rag doll. Extremely dangerous.
    If I were going to do any modification like that I would use a block of steel so the whole seat frame and body were in contact with the block. Not just raised up by the small surface area of a spacer. Also it seems like there was only 4 threads holding that bolt on but the guy who used spacers. I would be using a longer bolt as well for added security. From the factory, that bolt has more than 4-5 threads securing it
    smitty99 likes this.
  18. Aug 5, 2017 at 1:23 PM
    #38
    cliffyk
    Cliff
    Saint Augustine, FL
    I am (MSME MIT '71) and the manner In which I raised it is quite safe...
  19. Aug 5, 2017 at 2:24 PM
    #39
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    My 16 with sunroof and I can "barely" wear my golfin' cap.... Never a hat like that.... I guess it's all in the make-up of the body..... Some are tall in the legs...others tall in the torso...!!
    5'-11" and my head is almost (1/2") from touching with the sunroof....!! Damn thing eats up tons of space..
    Wish it were gone.... did not ask for it but I fell in love with the truck......!! Had to take her with all her faults... just like the "ole lady"...hehe
    (hope she doesn't see this)....
  20. Aug 5, 2017 at 2:48 PM
    #40
    smitty99
    Scottsdale
    Agreed.
