Problems starting
Discussion in '1st Gen. Tacomas (1995-2004)' started by Juanmartinez22, Nov 5, 2016.
  1. Nov 5, 2016 at 7:39 PM
    Juanmartinez22
    Juanmartinez22 [OP] Member
    My Tacoma was sitting up for about 8 months.. about a month ago it was cranked up and ran fine.. after that the key ignition switch was changed out. Never cranked it again till a few days ago. Came to start it and had a dead battery.. got the battery charged and noticed they had no gas.. put gas in it, and still wouldn't start.. cracked the fuel line where you pressure test by the motor, and no gas.. checked the fuses and relays, thought everything was good.. pulled the fuel pump and checked it with a battery, worked fine.. put it back in, checked the secondary filter, and no gas.. went back to the relay, and jumped it, got gas all the way to the fuel rail.. but still won't start.. tried starting with starting fluid, nothing..
    it's a 99 Prerunner 2x4. 3.4l
    Can someone please help me out with this?
  2. Nov 5, 2016 at 7:45 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Maybe try another battery if you can
  3. Nov 5, 2016 at 7:50 PM
    Juanmartinez22
    I have a new one in now.. it's turning over fine.. just not cranking up and running
  4. Nov 5, 2016 at 8:03 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Check engine ground wires are good. Shit, other than maybe a faulty coolant temp sensor I'm no help. I'm rooting for you! Good luck
