Problems unlocking/locking truck with fob and button
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mcymanny, Apr 11, 2025.
  1. Apr 11, 2025 at 1:07 PM
    Mcymanny
    Mcymanny [OP] Member
    Emmanuel
    Heyo Tacomaworld,
    Out here defeated, broken and devastated. Over the past year-ish my truck stopped locking on me, I played around with the fuses hoping it was that easy fix and today I finally got around to switching out the door lock actuator on my driver side and it still won’t lock/unlock…
    Anyone got any feedback on this? Similar problems diagnostics? Any leads would be awesome
    To clarify none of my doors lock or unlock electronically… neither with the button inside of the truck or the keyfob…
    I did add a pop-o-lock for my tailgate that could be part of the problem?
  2. Apr 11, 2025 at 1:20 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    Why would you switch out the actuator on the drivers door when none of the doors work? Did the issue start when you installed the PNL? If so disconnect the PNL and see what happens.
    lastcall190 likes this.
