Problems with 2021 4Runner TRD Pro wheels install
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jschwerdtfeger, Apr 3, 2021.
  1. May 14, 2021 at 4:11 PM
    #61
    Benjaminfrankss
    Benjaminfrankss Member
    Benjamin
    2019 Tacoma trd off road
    Borla exhaust, leveling kit, s&b intake
    I gave up. I wanted them to work but I didn’t want to mess with getting the wheels machined or using wheels spacers or grinding down the hub. I had to fight Toyota to get them to return the wheels since they were special order. Even though I only opened one box. I ended up keeping the stock wheels and getting new ko2s installed and I couldn’t be happier.
    embedded rock and usmc2msu like this.
  2. May 28, 2021 at 11:51 PM
    #62
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Superior Industries makes the makes the OEM wheels. Far from an aftermarket company.
  3. May 31, 2021 at 6:10 AM
    #63
    Xplosiv
    Xplosiv Well-Known Member
    Jeff
    Lewisville, TX
    2021 OR DCSB Black 99 Corvette FRC
    265/75/16 AT's, Cali Raised Sliders, BAMF RTT Rack
    Thats still an aftermarket company. Contracted by the OEM. If they are not owned by the manufacturer then they are aftermarket.
  4. May 31, 2021 at 6:20 AM
    #64
    splitbolt
    NW Arkansas
    So a GKN locker is not OEM, but an Aisin transmission is? Got it...
    In this context, you and I have differing definitions of aftermarket vs OEM.
    Magiriano likes this.
  5. May 31, 2021 at 6:57 AM
    #65
    Xplosiv
    Jeff
    Lewisville, TX
    I mean, my definition goes by the industry standard. But if you want to split hairs go right ahead. Stanley Electric Co is an aftermarket company, that is contracted by most vehicle manufacturers to make their factory equipped lighting.
  6. May 31, 2021 at 8:19 AM
    #66
    CDNTacoma2019
    CDNTacoma2019 Well-Known Member
    Ontario, Canada
    2019 SR5 DCLB 4x4
    Hopefully Toyota adds a disclaimer these wheels DO NOT fit the Tacoma. If they require machining they are definitely not a bolt on and go mod. At least the fix is easy for people who already bought them.
  7. May 31, 2021 at 11:36 AM
    #67
    splitbolt
    NW Arkansas
    It you who choose to split hairs.
    My original statement was, "Superior Industries makes the OEM wheels"...then you came in with your bullshit.
  8. Jun 1, 2021 at 5:37 AM
    #68
    Xplosiv
    Jeff
    Lewisville, TX
    Lighten up Francis.
    WVIrish and JJ Diablo like this.
  9. Sep 9, 2021 at 8:26 AM
    #69
    Revolver34
    Revolver34 Active Member
    Daniel
    2021 Tacoma TRD Sport 4x4 Cement Gray
    Anyone run the wheel spacer option? I have them on my truck but getting them off and on is a pain. I would like to fix it but don't want to grind my hub or put too large of a spacer on there cause I like the way they sit currently. Anyone got a link to a wheel spacer that would work but wouldn't push the wheels out that much?
  10. Sep 9, 2021 at 8:51 AM
    #70
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    Bora makes 1 inch spacer . But it will shove your wheels an inch out. No other choice except to bring wheels to machine shop or grind the hubs as posted previously
  11. Sep 9, 2021 at 8:54 AM
    #71
    Revolver34
    Daniel
    Man, I really want to keep the wheels but don't like those options. Might just get some Fuel Rebels and sell the TRD pro's.
  12. Sep 23, 2021 at 6:56 PM
    #72
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    That's not how aftermarket works.
    Original equipment manufacturer is the manufacturer of the original equipment. Toyota is the original manufacturer for many parts on the vehicle, but they are not the only OEM.
    Companies like Enkei will often have OEM and aftermarket divisions. They occasionally even sell the same parts through both supply chains, but that doesn't mean they're the same. Even Toyota has OE and aftermarket parts, and again, they're not the same.
    When a company sells a product to Toyota and that product gets installed at the factory, that's original equipment, and the company that sold it to Toyota is the original equipment manufacturer. It doesn't have to be Toyota.
    The TRD wheels that this thread started with are Toyota aftermarket wheels (they are either PIO or DIO, 4Runner TRD Pro's leave the factory with black steel wheels as original equipment).
    Jeff
  13. Sep 23, 2021 at 7:13 PM
    #73
    Tmck06
    Tmck06 Active Member
    Tommy
    2006 Red X Runner
    K&N filter kit
    These 4Runner wheels fir fine on my 2021
  14. Nov 14, 2021 at 7:25 AM
    #74
    Soundguy89
    Soundguy89 Member
    I bought these OEM TRD Pro wheels last week. Took to my tire dealer to have them installed and then got the call that they would not fit. I found this thread and forwarded to him. They did not want to do the grinding, but found a 1/4" spacer they feel will solve the problem. Will update when they are on. Hoping this works. Didn't take much research to find this isn't a fluke. Something has changed with these wheels specs.
    brandon78lusch likes this.
  15. Feb 10, 2022 at 4:22 PM
    #75
    sandytaco17
    sandytaco17 Member
    2019 Quicksand Tacoma
    how is the 1/4 spacer working out for you? Trying to install trd 17 on my sr5 now and they are super tight. Not sure what my options are since the trd rims are non refundable from the dealer :/
    JJ Diablo likes this.
  16. Feb 10, 2022 at 4:39 PM
    #76
    Soundguy89
    Soundguy89 Member
    Sorry I forgot to give an update. The 1/4” spacer is working just fine. No issues at all and made the wheels fit.
  17. Feb 10, 2022 at 4:41 PM
    #77
    sandytaco17
    sandytaco17 Member
  18. Feb 10, 2022 at 8:57 PM
    #78
    Soundguy89
    Soundguy89 Member
    I’m really not qualified to give advice on this issue. But I switched to this wheel partly because my Venomrex wheels rubbed due to the offset. Having too big of a spacer I imagine could have the same affect and cause rubbing. Would defer a more definitive answer to someone with a greater understanding of the issue.
  19. Feb 22, 2022 at 6:43 AM
    #79
    trailbuilt
    trailbuilt Well-Known Member
    So I think it is clear that the rear hub needs to be grinded to make these fit in the rear, but I am still unclear about the front...
    Some say you need to remove the dust cap but it seems most people have not done anything to the front. Can anyone confirm what needs to be done in the front?
    I am not worried about removing the dust cap, I think it will stay dry around the nut. If you were really worried about it you could remove the nut and put some rtv around the axle the put the nut back on, similar to what you do on most transfer case or diff flanges.
  20. Feb 22, 2022 at 7:01 AM
    #80
    Sungod
    Sungod Well-Known Member
    St Augustine
    I know this is an old post, but it is a real WTF? moment. They won't grind down the hub, but they were willing to thrown on a spacer?? :eek::eek::eek: I would rip those things off immediately and either machine the wheels or grind the hub. Spacers are a bad, very bad idea.
