problems with breaks when sliding
Discussion in '2nd Gen. Tacomas (2005-2015)' started by doodle_cakes, Jan 10, 2010.
  1. Jan 10, 2010 at 3:54 PM
    doodle_cakes
    doodle_cakes [OP] Well-Known Member
    Canada
    08 Taco SR5 5lugger
    If my truck is sliding on ice and I push the break I get a horrible grinding sound. I can also feel it from the pedal on my foot. It is similar to the grinding sound you can get from a manual transmission (which mine is) when you mess up and grind the gears.
    Usually when this happens I am in neutral because I am going very slow trying to stop at a stop sign or light. I can only pump my breaks very lightly to avoid this.
    08 2x4 access cab 4 banger is my truck.
  2. Jan 10, 2010 at 3:55 PM
    nothingsleft
    nothingsleft Member
    2010 Timberland Mica
    It's just the ABS. The all do this. You are not supposed to pump the brakes it does it for you.:)
  3. Jan 10, 2010 at 3:59 PM
    Jigzor
    Jigzor Well-Known Member
    Pennsylvania
    17 DCSB Silver Sky
    An anti-lock braking system, or ABS is a safety system which prevents the wheels on a motor vehicle from locking up (or ceasing to rotate) while braking. That would be what you feel.
  4. Jan 10, 2010 at 4:06 PM
    NWtacoma
    NWtacoma Well-Known Member
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    its the ABS
  5. Jan 10, 2010 at 4:21 PM
    Chester
    Chester Well-Known Member
    Nor Cal
    07 Access Cab TRD-OR M-V6 4x4
    Rear Spring TSB,Locker Mod,In bed cargo lights,Fully de-badged,TRD Seat Covers,Trailer Harness Relocation,Painted wheels,Extra tie-downs,5100's,Biceman lighting,09 stereo with sirius & isimple ipod interface,Rear diff breather mod,K&N Air Filter
    Dont push on the pedal so hard,or get your brakes checked.If your pushing hard enough at a slow speed to engauge the ABS your nailen that shit.
  6. Jan 10, 2010 at 4:33 PM
    squad314
    squad314 Thinks he's Steve McQueen
    Marc
    Into the mystic....(foggy Saint John, NB)
    TRD Sport+Leather 4x4
    Front 5100's @2.5", Rear 5125's with AAL. Light Racing UCA's, Factory hood deflector, Sirius Sportster 5, TRD air filter, Weathertech's f&r, "Hello Kitty" steering wheel cover.
    All ABS systems are similar but respond/react differently.....The first time mine activated in my Tacoma on ice the noise startled the hell out of me. It's normal,no worries.
  7. Jan 10, 2010 at 5:34 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Your brakes are working properly so that you don't break anything.
  8. Jan 10, 2010 at 5:52 PM
    IndigoTaco
    IndigoTaco Well-Known Member
    07 Access Cab Sport 4x4
    see thread on "ABS on this truck is dangerous..."
  9. Jan 10, 2010 at 6:15 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    09 DC 4x4 Blown Honda VTEC V8
    trd exhaust,step bars,vent visors,bed lights,tailgate mod
    the abs grunting
  10. Jan 10, 2010 at 6:43 PM
    steviestyles
    steviestyles The "Search" tab is your friend!!
    Colorado Springs
    07 DC 4x4 TRD Off Road
    Bone Stock
    You shouldn't be in neutral either. You want to use the engine to help you break as well.
  11. Jan 10, 2010 at 8:14 PM
    doodle_cakes
    Canada
    08 Taco SR5 5lugger
    It's definitely not the abs just grunting and working properly. I'm not pushing the pedal to hard; I can actually barely push it at all once this happens. I know what abs should sound like, but this sounds like the truck is half in gear and crying in pain.
    I showed this to my friend who I bought the truck from and he said he had never had this sound before, and his 09 4 banger taco doesn't make this sound.
    I guess I'll take her to the stealership if no one here has had a similiar issue + solution. Should be warrantied anyways.
    edit - oh yea, when it starts making this sound it begins to slide even worse, as if the breaks are not on, which is why I have been having to pump them otherwise I just keep sliding and grinding.
