problems with dough thorley long tubes
Discussion in 'Performance and Tuning' started by kris219, Jan 9, 2010.
  1. Jan 9, 2010 at 3:08 PM
    kris219
    kris219 [OP] Well-Known Member
    Kris
    miami
    tacoma trd
    spindle lift with dakar leaf pack, blacked out headlights and tailights, satoshi, debadged, HID headlights n fogs, flowmaster 40 single in dual out
    im trying to convince my dad to let me get dough thorley long tubes for my 4.0. he's old school so he thinks hes gana have to torque the bolts that hold the headers to the block every three months or something. is this true? and when you use the o2 simulator, does the check engine light still work for other stuff?
  2. Jan 9, 2010 at 3:10 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    If he thinks that then buy some loctite. There's some that formulated for heat.
  3. Jan 9, 2010 at 3:35 PM
    bsfarmer
    bsfarmer Member
    Brad
    Dixon, IL
    2008 Base Model 4x4 Access Cab
    265/75/16 TSB rear
    You might have to tighten a couple of times. Every header or manifold I've put on, the bolts have loosened a couple times before they stay put. You might want to try Stage-8 header bolts, I've heard great things about them.
  4. Jan 9, 2010 at 4:40 PM
    XrunnIT
    XrunnIT Well-Known Member
    Austin, TX
    1GR-GZE X-Runner
    Built Motor by LC Engineering Boosted by TRD
    I've never had any issues with mine coming loose. After you torque them down, go out for a spin, let the headers get hot. Come back, let the motor completely cool down, re-tighten the headers, and you should never have to worry about them again.
    the o2 sim only eliminates the CEL for the front cats. All other CELs will still illuminate as they are supposed to.
  5. Jan 12, 2010 at 7:12 AM
    c0astie31
    c0astie31 TACO SUPREME
    Dennis
    Long Island ny
    2011 4Runner Trail Edition
    A LOT
    i installed my o2 sim and i was told this is for the rear cats.
  6. Jan 12, 2010 at 8:28 AM
    XrunnIT
    Austin, TX
    1GR-GZE X-Runner
    The o2 sensor monitors the health of the front set of catalytic converters. The rear set of cats are unmonitored. So you only need the o2 sim if you have bypassed the front cats.
  7. Jan 12, 2010 at 11:29 AM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    All the o2 sim. does is tells the computer that the cats are there and functioning properly!
  8. Jan 12, 2010 at 11:37 AM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    Why don't you get some of those "Stage 8 locking fasteners" ?
  9. Jan 15, 2010 at 5:13 PM
    RELLIM
    RELLIM Well-Known Member
    IOWA CITY IA
    2010 ACC CAB 4X4 V6 SR5 TRD
    Scan Gauge II, AFE air filter, charcoal intake filter delete Fitch Fuel Catalyst, Alpine iDA-X303, AMS OIL (ENGINE) Bilstein 5100 RHA series
    usually u have more problems with taking the bolts loose.
