Problems with factory stereo - 09 Access cab
Discussion in 'Audio & Video' started by redjessie, Jan 19, 2009.
  1. Oct 4, 2009 at 8:53 AM
    motomem
    motomem Member
    Brighton, TN
    Tacoma
    Toyota has already replaced my radio once now the new one is doing goofy things too. Sometimes it just shuts off other's it just comes on. Last one I had to leave the truck with them so they could verify I was telling the truth. Then a month later I bring it back and blow an afternoon. Guess I will go through the same thing again.
  2. Oct 4, 2009 at 9:08 AM
    WCJR
    WCJR Well-Known Member
    W
    If it is a delphi tell them to keep it. If you cant get them to give you a panasonic then get to the big toyota complaint dept. You have to keep complaining to everyone you can think of.
    Remember the squeaky wheel gets the grease or a new radio.
    They probably gave you a recon unit that was gone over by the jerks in mexico. These are the idiots that make them in the first place.
  3. Nov 15, 2009 at 8:43 AM
    tacomaradio
    tacomaradio New Member
    California
    4 cyl tacoma ext cab
    I purchased my 2009 tacoma in September 2008. Since then, I have replaced the radio 2 times. I am now waiting for the radio that is supposed to work. It's been about 4 months since that one was ordered. I'll wait until after Thanksgiving for a solution, after that, will go to an Attorney. If you are experiencing the problems described above, it is a mfg problem. Since it is not a safety issue, Toyota will NOT come to you. I was really excited purchasing this truck, now not so much. Folks, take this issue to the dealer. The parts guy told me these go for 1300.00 to 1500.00 retail. So, toyota owes you that much at least. Good luck.....
  4. Nov 15, 2009 at 10:39 AM
    bass mechanic
    bass mechanic Well-Known Member
    colorado springs, colorado
    2009 tacoma Access cab TRD offroad in black
    none
    dude, that is the dumbest thing i have heard, its a RADIO and everyone knows the factory one is a POS! stop your whining and to buy a radio! anything you buy will sound better then OEM anyway, dont hate the entire truck over a stupid radio!
  5. Nov 15, 2009 at 11:03 AM
    NuovoTech
    NuovoTech Well-Known Member
    Upper Left Corner
    09 Tacoma 4x2
  6. Nov 15, 2009 at 7:56 PM
    808matt
    808matt Well-Known Member
    hawaii
    19 Ranger
    HAHAHA. i guess he bought a tacoma for the radio...
  7. Nov 17, 2009 at 5:59 AM
    flygirl
    flygirl Active Member
    ct
    2013 Tacoma TRD Sport Access cab
    I'm having the same problem with mine but it behaves when I play original CDs & not my home made ones. Working 2nd shift , I can see this as a major time consuming problem which is difficult to prove since its intermittent.
  8. Dec 11, 2009 at 11:37 AM
    Collins
    Collins Well-Known Member
    North Carolina
    09' Tacoma, 2.7L, 5spd, 4x4
    My 09 is doing the same thing. It happened when i first bought
    it earlier this year and i thought maybe i had hit the 'mode' button
    on the steering wheel by mistake.
    But today, i started the truck and the radio came on like usual
    except there was no display...and i couldnt turn it off.
    None of the buttons would work. I turned the ignition off
    and on again...same problem. After about 10 minutes of
    playing the radio turned off. I stopped and did the off/on thing
    again and it came on and the display was on too.
    Seems back to normal.
    Def. gonna look into another system as this one does blow.
    The volume thing is really annoying too...i've got to crank
    it to nearly half volume to even hear it while on the road.
    PC
  9. Dec 15, 2009 at 8:02 PM
    Chad
    Chad Well-Known Member
    Chad
    Cary, NC
    09 V6 Access Cab TRD Sport
    Kenwood DMX-7704S Headunit -- Blackvue DR-470 Dashcam -- Pioneer TS-A1685R Speakers in Front -- Suntek CXP 40 Front Tint -- Access Vanish Roll-up Tonneau -- Wet Okole Seat Covers -- Fog Lights on Anytime -- PnL Powered Tailgate Lock -- DTRL "Stealth Mode" -- LED Footwell and Cup Holder Lights -- Map Lights ON with Dome Light -- Shorty Antenna -- AC Line Extension Mod -- Access Cab Rear Headrest Removal
    Mine has decided to not use the volume knob anymore. A real pain, but the steering wheel volume control works. Will show it to them next week when I go in for the tranny TSB.
  10. Dec 16, 2009 at 10:56 AM
    fauskar
    fauskar Active Member
    Rick
    Wisconsin
    SR5
    Hitch
    Volume control stops working:
    1. Set the volume using the steering wheel control until it shows "0" on the radio
    2. Turn the volume control on the radio in the clockwise direction; it should start working.
    Mine got screwed up and that's the only way to re-sync the two. There's no rheostat (variable resistor) used anymore. The radio pwr/vol is just an encoder.
  11. May 13, 2011 at 2:57 PM
    hectory
    hectory New Member
    Hector
    Hermosillo, Mexico
    10 Tacoma TRD Sport 4x4
    This morning this is how my stereo looked (see pic). Volume, power, everything worked, just the display is messed up.
  12. May 13, 2011 at 5:19 PM
    B R
    B R Active Member
    Los Angeles, CA
    '10 AC 4 Banger Auto
    It's all part of the same problem that a lot of people have. The radio is crap even when it's working properly. Do yourself a favor & install something else, whatever it is, it will be better than what Toyota provides.
