problems with idling with my 1st Gen
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ethan Stuva, Jan 28, 2023.
  1. Jan 28, 2023 at 10:52 AM
    Ethan Stuva
    Ethan Stuva [OP] Member
    Ethan
    1996 black V6 TRD
    4 inch lift, 1.5 inch spacers, with 33s
    I removed the air intake manifold in order to get better access to the power steering pump. I put it back in but ever since then, idling the truck has been terrible. It sputters, revs are low, and shakes the cab. truck runs perfectly when driving. I changed the air filter (very dirty) and it worked for a little bit but went right back to sputtering while idling.
    It's so weird because before, the truck was running perfectly but after playing with the manifold, it sounds terrible. Is there something that needs to be reset because I feel its just an intake issue.
  2. Jan 28, 2023 at 11:00 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Leaks in the hose sucking in un metered air? Did you crack the hose check the bottom .
    You mean the Air intake from the air filter to the Throttle body?
    Kevins60 and Taco critter like this.
  3. Jan 28, 2023 at 11:36 AM
    Ethan Stuva
    Ethan
    1996 black V6 TRD
    Yea, air Intake from the filter to the throttle body. I was wondering if that was problem but never fully looked into it. Is soapy water a good way of checking?
  4. Jan 28, 2023 at 11:47 AM
    Bivouac
    As your sucking air into the engine soapy water is not a really good idea.
    I just look for visible signs .
    Some people use a unlit propane torch but be very careful.
  5. Jan 28, 2023 at 11:57 AM
    Ethan Stuva
    Ethan
    1996 black V6 TRD
    ok thank you.
