problems with MAF Calibrator
Discussion in 'Performance and Tuning' started by metric310, Feb 13, 2011.
  1. Feb 13, 2011 at 9:23 AM
    metric310
    metric310 [OP] street taco
    Alejandro
    clinton, ut
    07 prerunner lifted, bumping loud
    3' lift, 10 inch subs, custom TRD sticker, BHLM, leather arm mod, pioneer avic 700 stereo, 5% tint all around
    So i put in my URD MAF calibrator yesterday and now my truck is running like poop. if i floor it, it like struggles to jump from 1st to 2nd gear.it feels like it jumps directly to 3rd.. and then it tops out at 55, it wont go faster than that, and the revs star at about 4.7k. but if i drive the truck normally without flooring it, it runs just fine. anyone else have these problems before?:confused::confused:
  2. Feb 14, 2011 at 6:37 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Sure that you have the right map for your truck and any other assorted add-ons? If you bought it new, talk to URD, if you bought it used, talk to URD.
  3. May 14, 2011 at 7:03 PM
    06TRDZombieHunter
    06TRDZombieHunter Well-Known Member
    Robert
    Hillsboro, OR
    06 TRD Sport DCLB
    K&N Intake System Port and Polish of TB x2 E3 Diamondfire Sparkplugs 2.5" Leveling kit 32" BFG A/Ts Zombie Response decals Custom painted grill, trim under headlights, scoop, intake and manifold. No more mud flaps, Temp gauge inside intake box, BHLM, extra D-rings in front of bed, No more plastic storage box behind rear seats. More to come.
    Did you ever find the issue? I just installed my tonight and it wont rev at all.. its like the throttle position sensor is unplugged. . (its not) But I checked all my connections and fired off an email to URD, hoping for a quick response.
  4. May 17, 2011 at 12:20 PM
    Murd3rd
    Murd3rd DO WORK!!!
    Garrett
    Abilene, TX
    07 Access Cab 5-Lug...Murdered-R.I.P. 30JUN11
    DJM Lowering Kit, Xrunner front struts and springs, QA1 12-way Adjustable Rear shocks, BHLM, Undercover Bedcover, K&N IK, Doug Thorley Header, URD MAF Cal, ScanGauge, GO-Baby-Go Mod(purple wire mod) Cherry Bomb glass pack dumped right after rear axle, 99-04 Mustang GT wheels Painted Black, Pre-runner Leafs, Hellwig Rear Sway-bar
    check your wiring. did you wire it yourself or get the plug-n-play?
  5. May 18, 2011 at 7:41 AM
    06TRDZombieHunter
    Robert
    Hillsboro, OR
    06 TRD Sport DCLB
    I wired mine myself. . Had everything hooked up according to the instructions.. Problem was that I had the wrong instructions. After lots of emails to URD, a phone call, and some complaining on my part about vague instructions we realized I didnt have the right set. We identified the one wire I had hooked up that didnt apply to my rig and I cut it... re connected the batt and reset the remaining throttle position sensor codes and was back in business.
    Im still making runs on the Butt Dyno to see if this performance mod makes any difference.
  6. May 18, 2011 at 7:22 PM
    maxpower29
    maxpower29 Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    awesome. Let us know asap when you find out
  7. May 19, 2011 at 8:06 PM
    06TRDZombieHunter
    Robert
    Hillsboro, OR
    06 TRD Sport DCLB
    It might just be the $200 dollars lighter my wallet is now, but I do think I can feel the engine put out a little more umph when climbing the RPMs. As I accelerate at half throttle and hold there the truck accelerates like it did before but gets a little giddy up at two distinct RPMs. Cant tell you those spots specifically right now but if anybody has "felt" the VVTI (Variable Valve Timing Intelligence) technology kick in. . Its kinda like that.
    If you have no idea what im talking about search in on google or Wiki. Basically this technology is like having two different cams available, one mild for low RPMs, and one that holds the valves open a little longer at higher RPMs for more performance. Toyota Honda, Mazda and others all use it, but call the tech different names.
  8. May 20, 2011 at 8:17 PM
    06TRDZombieHunter
    Robert
    Hillsboro, OR
    06 TRD Sport DCLB
    Yup.. Thats it in a nutshell. I realize what I wrote earlier is hard to understand and makes nearly no sense..
    The URD MAF calibrator makes me feel like there is a tiny performance gain, but it might be just from the time/money I spent on it.
    Rob
