Problems with my E-locker
Discussion in '1st Gen. Tacomas (1995-2004)' started by ChiefThickums, Dec 1, 2009.
  1. Oct 17, 2011 at 8:36 PM
    Stout890
    Stout890 Well-Known Member
    Palmdale ca
    99 prerunner sr5
    10" sub, OME881 on Bilstein's, 3" all-pro leaf springs with billies in the back, JBA UCA's, bed cover with custom LED lighting, k&n intake and DT headers, OEM E-locker in the rear. 32" BFG KO2 on steel D window wheels, suicide knob. rebuilt 3RZ w/ stage 1 cam and balance shaft delete . big 3 mod, all new suspension and body mount bushings. cat back magnaflow exhaust.
    great find..yeah he talks a little bit about the bench test but doesnt go into detail. i wonder what a heater relay is?
  2. Dec 23, 2011 at 8:37 PM
    demo243
    demo243 Well-Known Member
    Devon
    Topsfield MA
    2015 DCLB TRD 4x4
    Looks like I am going to be joining the ranks of e locker rebuilders. I have a little bit more trouble shooting, but so far done everything including the grey wire mod and still no engagement
  3. Apr 26, 2017 at 5:32 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    I know this is an old thread but in case somebody uses it: Be extremely careful when bench testing the locker. I jammed my motor stuck and had to take it all apart to get it unstuck. Huge PITA! At least it worked, and works again lol
  4. Apr 26, 2017 at 6:22 PM
    taco03Trd
    taco03Trd 03 rig trd v6
    Carlos
    Riverside ca
    03 DC prerunner trd v6 2wd
    Ome 881 5100's jba's looking for more
    My wont work idk whats wrong i check power to the switch and is got power inside the cabin maybe a bad switch? Whats next were do i check now
  5. Apr 26, 2017 at 9:37 PM
    TireFire
    Olympic Peninsula
    Whattt??
  6. Apr 26, 2017 at 9:47 PM
    Tucker771
    Tucker771 Tacoma Beast
    Tucker
    Raleigh, NC
    2004 Tacoma Doublecab 4x4 TRD
    Gray wire mod, 4" coil lift, 2" block lift+2" AAL, rear air bags, re-located trailer wiring plugs, trail gear front bumper, kicker sound w/pioneer in-dash, 8" kicker sub, airaid MIT kit, trail gear rock sliders, arrow antenna, blacked out grille, HID kit, Smittybilt 8k winch, extended brake lines, LED overhead lighting, LED turn signals, Explorer Rock Lights, removable doors, Re-wired 4x4, Roof Rack
    anyone know why my ABS light won't go off after putting the e-locker on and 4lo? I went and turned the locker and 4lo off and the ABS has been on ever since
  7. Apr 26, 2017 at 9:52 PM
    TireFire
    Olympic Peninsula
    Bad sensor maybe... have you tried that your abs still works?
  8. Apr 26, 2017 at 9:53 PM
    Tucker771
    Tucker
    Raleigh, NC
    ABS is essentially disengaged after that incident. itll lock the tires up if brakes are slammed
  9. Apr 26, 2017 at 9:54 PM
    TireFire
    Olympic Peninsula
    Okay can't help then... except maybe duct tape over the dash light and don't look back. ABS sucks! Good luck
  10. Apr 26, 2017 at 9:56 PM
    Tucker771
    Tucker
    Raleigh, NC
    ive been riding like this for 3 years lol:burnrubber:
    TireFire[QUOTED] likes this.
