Problems with my gas level sending unit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by McJosh, Dec 4, 2009.
  1. Dec 4, 2009 at 8:04 AM
    McJosh
    McJosh [OP] avidoffroad.com
    Josh
    Chandler
    2005 Reg. Cab 5 lug Tacoma
    Pioneer AVH-p2300DVD, 12" Memphis sub and Alpine MRP-M650 amp, 32" BFG AT tires and KMC wheels, tinted windows, satoshi grille w/ stainless steel mesh, Avid front & rear tube bumpers, Cobra wx75 CB with 3' firestik, GaragePro bucket seats, FlowMaster 40 series, aFe CAI, Black head lights, LoJack and Autopage alarm installed, Avid sliders.
    So about four days ago, I put gas in it and I noticed that it didn't move. Last night I was driving and the light turned on that I needed gas but then slowly moved back to it's position and hasn't moved anymore but it's something I worry about since I don't want to be stranded. If you guys have experienced this or know how to fix it, let me know.
  2. Dec 4, 2009 at 8:05 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Sounds like iut could be a bda sending unit.
  3. Dec 4, 2009 at 8:16 AM
    McJosh
    Josh
    Chandler
    Is it expensive to replace?
  4. Dec 4, 2009 at 8:17 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Not sure. I havent priced it out.
  5. Dec 4, 2009 at 8:19 AM
    McJosh
    Josh
    Chandler
    Oh, I looked at two last night and they were $28-$50 but they were universal so idk if it'll work.
  6. Dec 4, 2009 at 8:21 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I would get an OEM one. The sending unit is attached to the fuel pump, so you either have to drop the tank or remove the bed to get to it.
  7. Dec 4, 2009 at 8:22 AM
    McJosh
    Josh
    Chandler
    Dang. Sounds like hard work. : /
  8. Dec 4, 2009 at 8:23 AM
    McJosh
    Josh
    Chandler
    And expensive.
  9. Dec 4, 2009 at 8:29 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    its not hard. Easy if you have a second set of hands. Nothing to removing the bed. Just disconnect all the lights, and bumper lights, fuel filler, then un bolt the bed and remove.
  10. Dec 4, 2009 at 9:35 AM
    McJosh
    Josh
    Chandler
    Well I'm gonna call toyota and ask how much the part is and hopefully it's not too expensive. As far as my a/c and transmission lights not working, is that just a fuse?
  11. Dec 4, 2009 at 9:37 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Check all the fuses.
  12. Dec 4, 2009 at 9:38 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    It's starting to sound like you have a loose wire or something. Your sending unit may be fine.
  13. Dec 4, 2009 at 9:41 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    X2....
  14. Dec 4, 2009 at 9:41 AM
    McJosh
    Josh
    Chandler
    well not too long ago I got a dvd player. It used to say that I couldn't watch dvd's while driving so the shop guy took the cable that is supposed to go to the parking brake, and connected it to the ground cable. Is that what messed it up maybe?
  15. Dec 4, 2009 at 9:42 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Did the problem start at that time?
  16. Dec 4, 2009 at 9:44 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    I doubt that caused it, but a loose connector or shitty splice somewhere could. You could always try to remove that one wire from the ground and see what happens. It will help build your troubleshooting skills.
  17. Dec 4, 2009 at 9:44 AM
    McJosh
    Josh
    Chandler
    well i left the harness unconnected to anything. so the stereo harness was just hanging for a day and I noticed the lights stopped working. (this was before doing any of the ground stuff) This happened to my brother, he did the same thing but it was just a fuse. Would it be the same for me?
  18. Dec 4, 2009 at 9:45 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Try it and find out
  19. Dec 4, 2009 at 9:46 AM
    McJosh
    Josh
    Chandler
    yeah I'm gonna go get some fuses. I still think the fuel thing needs to be replaced though. That happened before I put the new dvd player or anything.
  20. Dec 4, 2009 at 9:49 AM
    McJosh
    Josh
    Chandler
    Does the dealer do things like this? I took it to an oil change and that day i filled up but it didn't move.
