Problems with Pedal Commander
Discussion in '3rd Gen. Tacomas (2016-2023)' started by timkins42, Jun 9, 2024.
  1. Jun 9, 2024 at 7:08 AM
    timkins42
    timkins42 [OP] Well-Known Member
    Tim
    Fishers, NY
    2021 Black Tacoma 4X4 TRD Sport Access cab
    None so far
    I installed a Pedal Commander on my 2021 Taco as there was significant delay's in the response from the gas pedal. I installed the Pedal Commander and 2 or 3 times since installation I have experienced the same problem. Pull out to pass someone and hit the gas pedal and NOTHING, had to pull back in and pump the pedal for a response. I know if I take it to the stealership they will tell me "we could not get it to do the same thing, bring it back if it does it again". Any other suggestions?
  2. Jun 9, 2024 at 7:12 AM
    Akguy
    Akguy Well-Known Member
    way up north
    23' Silver OR DCSB
    BTL Y-Wing, RollTide! and Holling like this.
  3. Jun 9, 2024 at 7:24 AM
    Koolbreeze7
    Koolbreeze7 GRILL MAN
    Jon
    Jersey
    2017 TRD Sport 4x4 DCLB Black, Trail Limo. RIP- 2009, 2000, 91,89,87 trucks
    Rigid pod fogs, SpartanX stealth grill and hood LED's, 17" SEMA's on 275/70/17 Falken Wildpeak AT3W's, Fox 2.0 on all corners , TRD CAI, LEER 100XQ Blacked out, w/ Thule racks, and Cargo slider Flow master American Thunder "dual" exhaust, remote start, tint, TRD Pro grill and TRD shadow graphics, Alcan custom 8 leaf Spring Pack
    dont take it to the dealer with a PC installed.
    GawainXR likes this.
  4. Jun 9, 2024 at 7:26 AM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    Best place for that thing is the trash can .. a tune is what u need not some magical plug and play eBay junk .
  5. Jun 9, 2024 at 7:29 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    I'm not a fan of PC's or tunes. But if you must, get a quality tune.
  6. Jun 9, 2024 at 7:31 AM
    mtbkman
    mtbkman 2020 TRD Sport
    Metro Detroit
    2020 Trd Sport MT
    None yet
    Def don't take it to the dealer with it installed. You might have started the whole tune vs PC debate. I've had one for a while, was having issues, turned out it was a completely different issue. Got that fixed, seems to be working fine. Haven't had what you had. I will say this, there are more negative feedback from a PC as oppose to the tune. Maybe take it off, take it somewhere, see if there are any codes.
  7. Jun 9, 2024 at 8:21 AM
    GawainXR
    GawainXR Well-Known Member
    William
    2020 TRD Off-Road
    DashCam
    Ideally you should mostly ditch the PC in favor of a tune, only using the PC when in snow, ice sand or mud to deliberately retard the throttle response and avoid slipping.
    You disconnected the battery when installing it, correct?
    Ive heard issues about PC, check engine lights and other sort of problems , so I use an EVCx
  8. Jun 9, 2024 at 8:29 AM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    Banks Throttle Monstor here for over a year. Works flawlessly, trans even shifts better after the learning curve, reverts to stock in reverse or if it fails and it’s the same price as PC.
    The best alternative if you do not want a full tune.
    SilverBullit likes this.
  9. Jun 9, 2024 at 8:45 AM
    brian2sun
    brian2sun Well-Known Member
    California
    ‘21 TRD OR DCSB ‘17 4Runner Limited ‘97 4Runner SR5
    The ECT button on will help with throttle response. I had a tune and hated it (KDmax) and went back to stock, but then I added a Sprint Booster (basically the same as a PC) and an “always on” ECT module (so it comes on by default without having to turn it on) and I have been happy for a few years like that. I know there are better tunes now, but KDMax was supposed to be “the fix” for all the previous tunes before that… until that was replaced by a new version… and another… and another… and then a new tune altogether by a different company… and then they put out a new version… and another… and so on for eternity. IMO, it never ends because they know most people are obsessed with the latest and greatest, and there is money to be made on them. That’s my opinion of tunes, but regardless, try turning the ECT button on with your PC and see if that does it for you. You may even need to dial the PC down a bit to find the sweet spot.
    TacoEZ and Kolohe07 like this.
