Procharged Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SwiftJinx, May 4, 2021.
  1. May 4, 2021 at 4:38 PM
    SwiftJinx
    SwiftJinx [OP] Member
    Toby
    Florida
    2017 Tacoma TRD-Offroad
    -Bilstien shocks on emu888 springs -Icon add a leaf -Level kit -33x12.50r17 toyo open country’s -Fuel 17x9 wheels -Arb full body skid plate -Dobinson snorkel -Ripp Coil Packs -K&N filter -Rock sliders -Light bar -Procharger -Front bumper and winch
    2017 TRD Off-Road Tacoma
    https://youtu.be/kF6TW9EIDJM
    One of the very first Procharged tacoma’s and the first ever procharged tacoma in florida. Thanks to procharger, ovtune, and @PapaRee for making it happen and being able to do this.
    0-60 times were varying between 8-9.04 seconds
    We will soon be installing bigger fuel injectors, lighter pulley, and bigger fuel pump w/ a custom tune. A dyno video will be coming out shortly!
    Mods:
    -Icon add a leaf
    -Level kit
    -Fuel 17x9 wheels
    -Dobinson snorkel
    -K&N filter
    -Rock sliders
    -Light bar
    -Procharger
  2. May 4, 2021 at 5:27 PM
    Jproz
    Jproz Well-Known Member
    Bay Area, CA
    2021 LR Pro
  3. May 4, 2021 at 5:35 PM
    St0rm-Tr00per
    St0rm-Tr00per Well-Known Member
    SoCal
    2018 TRD OR 4X4 DCLB - Super White
    “Semi-Pro”/“PrOff-Road”
    Hmm … maybe a regearing would help with those 0-60 times?
  4. May 4, 2021 at 5:36 PM
    omg_miiiike
    omg_miiiike Well-Known Member
    Maryland
    2017 Tacoma TRD Off Road | DCSB
    So the 0-60 times were worse than stock?
  5. May 4, 2021 at 5:38 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Yeah, i was wondering the same. The 0-60 numbers are not that impressive in OPs post, no offence OP. I do understand he is running bigger tires and some added weight though.
    GillyLink and Amchuge like this.
  6. May 4, 2021 at 5:40 PM
    WaitingOnMyR1T
    WaitingOnMyR1T No longer waiting…
    Josh
    Portland, Oregon
    2020 White TRD Pro - Magnuson S/C & Rivian R1S
    His truck isn’t stock so it doesn’t have the same 0-60 time. It has added weight and larger tires.
    I’m curious about the tune, as I’m sure many with Magnuson’s are.
    SR-71A and SwiftJinx[OP] like this.
  7. May 4, 2021 at 5:41 PM
    omg_miiiike
    Maryland
    Correct - now it has a worse 0-60 time.
    I had Jeep some other piece of junk as a rental car with a 8-9 second 0-60, I felt like I was going to die merging on the highway.
    Junkhead likes this.
  8. May 4, 2021 at 5:44 PM
    WaitingOnMyR1T
    Josh
    Portland, Oregon
    I read the “0-60 times were varying between 8-9.04 seconds” as in “in the past”, before the Procharger. I’m curious about the times after install.
  9. May 4, 2021 at 5:45 PM
    omg_miiiike
    Maryland
    First sentence makes me think its present.. Spoke of the pro charger and stated 'times were varying'.
    Judging by the video.. I think we're still at 8-9.04 seconds.
    Skydvrr, ColtsTRD and Junkhead like this.
  10. May 4, 2021 at 5:47 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Judging by the video it accelerates similar or slower to my truck. I’m running 265/70/17 C load KO2s and SFOB premium tune.
    GillyLink likes this.
  11. May 4, 2021 at 5:50 PM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    Nice but what’s with the warning light ?
  12. May 4, 2021 at 5:52 PM
    ktbell444
    ktbell444 One who throws exceptions
    Karl
    ᚺᛖᛚᚺᛖᛁᛗ
    2020 Tacoma TRD Pro - Army Green
    About 1 second less though, max. The larger tires throw the speedometer off, so when it displays 60, it's likely going a little faster.
  13. May 4, 2021 at 6:07 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Hmmmmmmmmm :popcorn::popcorn:
    FishnTx, Junkhead and ktbell444 like this.
  14. May 4, 2021 at 6:25 PM
    SwiftJinx
    Toby
    Florida
    Truck is doing about 8 second 0-60. There is a lot of extra added weight plus the 33's slowing it down. A dyno session will be done next Friday to see the numbers it will be putting down. The power in the 0-60 mph range is not noticeable at all, but one boost kicks in around 68mph you can feel the truck starting to pull. Soon there will be a light pulley, upgraded fuel pump, and larger injectors to see what the engines potential is.
  15. May 4, 2021 at 6:28 PM
    SwiftJinx
    Toby
    Florida
    Maintenance light, forgot to clear after changing the oil.
    GOTSAND?18[QUOTED] likes this.
  16. May 4, 2021 at 6:29 PM
    SwiftJinx
    Toby
    Florida
    I have the spedo recalibration kit. It should be accurate.
  17. May 4, 2021 at 6:30 PM
    SwiftJinx
    Toby
    Florida
    Acceleration increased a lot for having a lot of weight and 33's on.. any speed 60mph plus you can definitely fell a difference and it pulling.
    SR-71A and Junkhead[QUOTED] like this.
  18. May 4, 2021 at 6:30 PM
    LongDistanceTaco
    LongDistanceTaco Well-Known Member
    Geoff
    California
    How much boost you running? One would think a procharger setup would make an appreciable difference on the bottom end.
  19. May 4, 2021 at 6:31 PM
    SwiftJinx
    Toby
    Florida
    The truck is running only 9.04 0-60 times but that's with all the extra weight and bigger tires. There is a big difference driving on the highway.
  20. May 4, 2021 at 6:32 PM
    SwiftJinx
    Toby
    Florida
    7.5 is what comes stock on the file provided by procharger. Its more than likely going to change when we get it custom tuned and upgrade the fueling and lighter pulley to see the potential of the engine.
