Procharger?
Discussion in 'Performance and Tuning' started by MachTac, Dec 21, 2015.
  1. Dec 21, 2015 at 9:18 AM
    MachTac
    MachTac [OP] Well-Known Member
    Kody
    MD
    Storm Trooper in boot camp
    2'' Spacer Lift 15% Tint Thrush Turbo Muffler It's All About That Bass STICKERS!
    My buddy has a Procharger that was bought for an eclipse. He told me that as long as I can find a place on my block to mount it, where it reaches the serpentine belt, it will work. Besides from the programming aspect, does this sound reasonable? I am very skeptical that there is even a place, with enough room, to bolt it on.
    Custom piping is a given.
    Thanks,
    Kody
  2. Dec 21, 2015 at 12:17 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Basically similar to the URD Rotrex s/c kit. There was a member on XRU some years ago that installed one in the similar location to URD's.
    What you would have to do is make sure it is the right size for your engine.
    Justus likes this.
  3. Dec 22, 2015 at 11:29 AM
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    I've seen some crazy custom blower setups so anything is possible. It all depends on how many bags of $$$ you're willing to throw at your truck.
    For example, I've seen a blower mounted on one side of the engine bay.....and it spun a "go-kart" axle which extended the width of the engine bay so it can connect to the drive belts. Unorthodox but still worked.
    To follow what the Lobster said, you'll need a few precision-measured custom one-off brackets to make all this work. Everything needs to be aligned and centered and cannot introduce any wobble-effect.
    With that said, you'll probably be better of selling the Pro-Charger for $$$ and use the funds for a URD kit.
