procomp 4" lift?
Discussion in '4 Cylinder' started by cadle09, Apr 18, 2013.
  1. Apr 18, 2013 at 5:15 PM
    cadle09
    cadle09 [OP] Member
    jake
    ohio
    08 single cab tacoma
    None yet, reason I joined gotta lurn more before I add the wrong stuff
    Did a lot of research decided on a procomp 4" lift for my 4cylander single cab tacoma anyone have some pic or insight about the lift?
  2. Apr 18, 2013 at 5:24 PM
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    9" of Super Bro lift
    I didn't even know they made a 4". :confused:
  3. Apr 18, 2013 at 5:35 PM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    2011 Mall Crawler
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
    It lifts 4 bangers 4" cuz of the stiff #700+ coils
  4. Apr 18, 2013 at 5:38 PM
    cadle09
    cadle09 [OP] Member
    jake
    ohio
    I was told the lift would leave me with vary little down travel. Any issues with that?
  5. Apr 18, 2013 at 5:44 PM
    Blacktacoma23
    2011 Mall Crawler
    Harsh ride! suspension cant even handle potholes
    at 4" of lift the CV angles would be steep also
    its a cheap kit, and I ditched it as soon as I could
  6. Apr 18, 2013 at 5:44 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    shitty ride.
  7. Apr 18, 2013 at 5:45 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Really just about any type of lift that uses stock control arms or spindles with no drop bracket limits down travel.
  8. Apr 18, 2013 at 6:02 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    Op I would stay away from the procomp lift are you 2wd of so get maxtracspindles up then addALeaf or new leaf pack in the rear with some 5100 that will ride better.
  9. Apr 18, 2013 at 6:03 PM
    cadle09
    cadle09 [OP] Member
    jake
    ohio
  10. Apr 18, 2013 at 6:03 PM
    PcBuilder14
    Brent
    Nor Cal
  11. Apr 18, 2013 at 6:09 PM
    Blacktacoma23
    2011 Mall Crawler
  12. Apr 18, 2013 at 6:11 PM
    PcBuilder14
    Brent
    Nor Cal
    Yeah, says it's for 04 Tacomas, which basically means 1st gens only.
  13. Apr 18, 2013 at 6:42 PM
    cadle09
    cadle09 [OP] Member
    jake
    ohio
    Idk why choosing a lift is so hard. What would you recommend? Just wanna clear 33s easy
  14. Apr 18, 2013 at 7:44 PM
    Blacktacoma23
    2011 Mall Crawler
    2WD or 4WD??
  15. Apr 19, 2013 at 12:32 PM
    cadle09
    cadle09 [OP] Member
    jake
    ohio
    I have a 4wd. And why exactly would somone lift a 2wd? Just for looks?
  16. Apr 19, 2013 at 2:31 PM
    Blacktacoma23
    2011 Mall Crawler
    Ok so spindles are out.
    you can do a 3" lift or hack your x member for a DB lift (range from 4"-6" kits)
    For lifting a 2WD is prob. the same as why they bought a pre runner in the first place b/c where they live
