Procomp 6" getting installed today
Discussion in 'Suspension' started by stephenm, Mar 18, 2011.
  1. Mar 23, 2011 at 10:10 PM
    #181
    stephenm
    stephenm [OP] Well-Known Member
    Stephen
    Socal
    thanks
  2. Mar 23, 2011 at 11:13 PM
    #182
    Lovelyn1
    Lovelyn1 Well-Known Member
    Danalyn
    Big Island, Hawaii
    05 Tacoma SR5 4x4 SuperWhite
    2 inch leveling kit......and that's all for now!!
    so did reducing ur tire pressure work? was that the cause of the problem??.....man reading though this forum and the hell you went through......lol, i hope it was worth it!!!!......
  3. Mar 23, 2011 at 11:23 PM
    #183
    stephenm
    Stephen
    Socal
    I will find out tomorrow even my tire gauge let me down... i'll grab another one in the morning lol hopefully it was only tire pressure!
  4. Mar 24, 2011 at 12:24 AM
    #184
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    can we get mod to make this a sticky for
    "WHERE NOT TO GET YOUR LIFT INSTALLED"
    dam, I hope everything works out. I did my own lift, including front dif spacer, rear leaf springs not knowing a dam thing about anything by myself. Granted i didnt' have to do a bracket lift but i am sure i could have figured it out and got it finished.
    To the OP I hope this works out for you and keep us posted
  5. Mar 24, 2011 at 10:01 AM
    #185
    stephenm
    Stephen
    Socal
    drove it on the freeway to go to work and it started feeling a little choppy past 55 mph (on the speedo - probably > 62 mph). nothing too scary though, I expected worse.
    Called 4wheelparts and the specialist confirmed what you guys've been saying that 50PSI is way too high. I'm getting a tire gauge in the morning to drop pressure down to 36 PSI.
    Now another question for you: at some point on the freeway +55mph I started hearing some noise coming out of the front right wheel area, felt like something was quickly vibrating thus producing some noise. I thought maybe it's trimmed fenders (below the bumper) that was resonating because of the air speed. I don't know. Anyone ever experienced something like that?
  6. Mar 24, 2011 at 10:05 AM
    #186
    DubVtundy
    DubVtundy ERMAHGERD
    Thayer
    Keyser West Virginia
    2010 white double cab
    8 inch alcan custom leaf packs, ome 885's powdercoated white, bilstein 5100's all the way around with 12 inch travel on the rear, Light Racing Upper Control Arms, Sway bar removed, 17x9 kmc strike. 35x12.50 nitto Trail Grapplers. Satoshi Grill made by (homertaco), Black Headlight housings,retrofits, Tinted Tailights, color matched grill, Bought a TRD sport hood,elite off road front plate bumper,elite off road sliders, 13% tint on the front windows, 5% on top of the facotry rear windows and back glass, 5% tint stip across the windshield, Lo Pro Truxedo tonneu cover, Herculiner bed liner, Weather Tech Window Visors, Exhaust- Flowmaster Super 44 dumped above rear axle, Maglight Mount on side of drivers seat, Scangauge II, Mossy Oak Camo Seat Covers, Weather Tech Floor mats, Spatter painted A-Pillars, Spatter painted headunit trim and shifter trim, Headunit= Pioneer 4300 double din touch screen, Speakers- Precision Power 3 way component stage, Precision Power 8 i
    well if you still havent taken air out of the tires it could still be that
  7. Mar 24, 2011 at 10:13 AM
    #187
    SilverTacoZack
    SilverTacoZack Well-Known Member
    Zack
    Elgin, SC
    2011 FJ trail teams
    This def sounds like a tire pressure issue. When I ordered my XD wheels, they arrived with the Terra Grappler tires already mounted up and everything. I bolted them on, and then went for a quick trip to settle the lug nuts so I could torque them down one more time, but I forgot to check the pressures first. I had some semi-serious vibrations and was worried the wheels hadn't been balanced right or something. However, when I got back I checked the tire pressures and one was only 18, and the other 3 were like 49 psi!! I adjusted everything down to 35 psi for all 4, and it's been riding perfect with no vibes since. So I think its highly possible all of your issues are due to the tire pressure alone.
  8. Mar 24, 2011 at 1:38 PM
    #188
    stephenm
    Stephen
    Socal
    got my gauge, here's what I measured...
    FR: 55psi
    FL: 55psi
    RR: 52psi
    RL: 54psi
    I'll drop them all to 36psi and see what happens. I had to drive again this morning, and yeah as soon as I pass 50mph there is a weird noise/vibration coming out of the front right area. If the tire pressure doesn't fix one the only thing I could think of would be the trimmed fenders that's vibrating hard
  9. Mar 24, 2011 at 1:42 PM
    #189
    K1992f
    K1992f Well-Known Member
    Kanon
    Dirty Hanover pa ...
    2012 tacoma TRD sport fully loaded
    6" fabteck 20" fuel hostage 33" nitto MTs
    Get ur air down and get back to us. Hope it works for ya
  10. Mar 24, 2011 at 2:12 PM
    #190
    stephenm
    Stephen
    Socal
    Ok they're all at 36PSI now, pretty remove 20PSI of pressure on each tire. I'm hoping that was it!
    I'll drive it in a few hours, gotta work a little bit now :p
  11. Mar 24, 2011 at 2:17 PM
    #191
    raycie
    raycie Well-Known Member
    Oahu, HI
    2013 DCLB / 2016 4R Trail
    In need of $$$
    Been following this too from the beginning..
    Almost seems like the closest thing to a male soap-opera..
    Hope the tire pressure work out OP..
  12. Mar 24, 2011 at 2:17 PM
    #192
    silvertaco82
    silvertaco82 No way, get real
    Bozeman, MT
    2010 AC TRD Sport 4x4
    TRD Seat Covers, Weathertech floor mats, Sockmonkey Decals, Pro Comp 6", 35" Nitto Trail Grapplers, 18x9 XD addicts, 20% tint, Kenwood Dnx 5120, 2 10" Kicker Shallow mount subs
    good luck man im ordering my 6" pro comp lift soon interested to see what it was... If thats all it is that shop should be shut down immediately for not realizing haha
  13. Mar 24, 2011 at 2:18 PM
    #193
    raycie
    Oahu, HI
    In need of $$$
    Screw work.. We are all at work checking in on the TW tube.. lol...
  14. Mar 24, 2011 at 2:20 PM
    #194
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    nvm, I read them... tire pressure will make your truck drive like crap
  15. Mar 24, 2011 at 6:25 PM
    #195
    stephenm
    Stephen
    Socal
    ok guys, it was the tire pressure! like I said I set them up to 36PSI and it drove really good and easy. I just can't believe this shop didn't think of that. Worse I can't believe they did look into it when I called them to check the tire pressure. When I picked up the truck they even told me 50PSI is what those tires need with this size's truck! Sure won't recommend them to anyone..
    Anyway, moving on!
    the bad news is that the noise/vibration is still there at around +50 mph. Hard to describe but I can hear and feel that is coming from the front right wheel.
    I've checked there and the only loose part is the trimmed fender. So my guess is that the fender is vibrating/resonating because of the air circulation around the wheel. As soon as I drop under 50mph it stops.
    anyone ever experienced something like that?
  16. Mar 24, 2011 at 6:39 PM
    #196
    dwalden2
    dwalden2 HBTFD
    Derick
    Blue Ridge, Georgia
    '05 TRD Offroad V6 6 spd
    SCS Stealth 6 Wheels, 285/70/17 STT Pros, Demello Offroad front bumper, 20" LED Bar, LED Fogs, LED interior lights, Wet Okole Seat Covers, Body Armour Rear Bumper, Smittybilt 10K winch, 3" OME Lift
    I have a strange vibrating noise comin from the right front area. I've been trying to figure out what it is and can't find it for the life of me. Mine is at low RPMs though, very rarely happens at higher speed. If I can ever find it I'll let you know what to check to see if it's the same for yours.
    Glad you got the truck drivin right. I was startin to get pissed for ya.
  17. Mar 24, 2011 at 6:48 PM
    #197
    toyo freak
    toyo freak Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    I dont know at first glance I thought you did...but I like the black grille surround;)
  18. Mar 24, 2011 at 7:10 PM
    #198
    chopperpat333
    chopperpat333 Member
    Denver
    T|X Pro TRD
    Yo, I would have your truck taken to another tire shop to have the balanced checked. That could be causing the vibration, the vibration may be a tire out of balance, causing the tire to rub at rotation. Since they over-inflated your tires, it is possible, they also screwed up the balancing.
    Could be worth checking. Could also be be a carrier bearing needing a drop.
  19. Mar 24, 2011 at 7:22 PM
    #199
    DubVtundy
    DubVtundy ERMAHGERD
    Thayer
    glad i could help ya with the tire pressure thing but also if you are hearing that noise at 50mph+ check to see if you wheels are balanced correctly could always be that also
  20. Mar 24, 2011 at 7:49 PM
    #200
    Gunner23
    Gunner23 Active Member
    Jim
    '16 Inferno TRD Off Road 4x4 Double-cab
    17x9 Mickey Thompson Sidebiter II Wheels 265/70R17 Cooper Discovery STMaxx Tires
    Is it consistent or does it change frequency and volume with different speeds? Mine would be really loud from 55-60 and then quiet down, always there but really bad at those speeds. Turned out it was a wheel bearing.
