Prodigy Brake Controller Install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MHillis, May 8, 2009.
  1. May 8, 2009 at 10:36 PM
    MHillis
    MHillis [OP] New Member
    Orange County
    08 Sport PreRunner White
    Sport TRD exhaust. Prodigy Brake Controller. Bed D-rings. Peripheral iPod® Adapter.
    Tekonsha Prodigy Brake Control Install
    I recently installed the prodigy brake controller on my 08 Taco and wanted to share how I did it. The first thing I found that was a problem, was the lack of places I could mount the sleeve for the controller.:confused: But, after a few seconds of thought I decided to mount it underneath the coin/junk pocket on the right side of the steering wheel.
    The images are after install but, what I did first was remove the pocket to mount the brake unit sleeve.
    To my joy, the back side of the pocket has a lip, so I didn't need to drill into the actual pocket. I drilled my holes and secured the sleeve bracket onto the pocket.
    The next step was wiring, which was straight forward and easy. Tekonsha makes a universal wire harness that works great; all you need to do is follow the directions (the yellow paper attached to the wires in the first picture) and plug the universal harness into the factory towing harness. I then put everything back together using zip ties to run the wire underneath the steering wheel.
    As you can see there is more than enough leg room and the location gives you easy visibility and control over the brake controller. Hope you guys like the location and install. I enjoyed doing this mod because it only took about 20 mins. and is a must have if you decide to pull a dump trailer or rv.:)
    This is me up at my cabin putting our dump trailer, Tacoma and brake controller to the test (there are some pretty steep grades up on the mountain).
  2. May 8, 2009 at 10:39 PM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    nice trailer, its nice when you can make shit easier
  3. Mar 22, 2010 at 11:02 AM
    roy826
    roy826 Well-Known Member
    Mississippi
    2010 Prerunner TRD Sport DC
    How do you remove this storage bin from the dash? does it just pull out? or is there something behind it I must disconnect? anyone know?
  4. Mar 22, 2010 at 12:03 PM
    roy826
    Mississippi
    Yes I have the auto. So it just pulls out? Nothing will break on it? I plan to mount it like the guy did above. That way I can buy that bin in the future if I want to sell without the drilled hole look. The setup above looks like it will work fine for me.
  5. Mar 22, 2010 at 12:32 PM
    TimS
    TimS Well-Known Member
    Tim
    Maine
    2010 DC tacoma/2005 access cab
    Rebuilt with flatbed 5100's, new spring packs
    Just did the controller a couple of weeks ago. We was going to put it where you did until the wife moved the seat up. It than was to close. I drilled a hole through the change holder in front of the shifter and will plug the controller in and use velcro to mount it. I plan on using the contoller in other vehilces.
    Good job.
