Product Interest Thread - Design Input Needed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KB Voodoo, Jun 8, 2015.
  1. Jun 8, 2015 at 6:21 AM
    KB Voodoo
    KB Voodoo [OP] Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    This came to me in my sleep last night. I'm not sure if a similar product exists. If one doesn't, I'd like input to develop it.
    This would be geared towards off-roading enthusiasts.
    The idea is a Utility Track that would bolt behind the factory side rails, to facilitate the mounting of hi-lift jacks, shovels, axes, etc....
    This is what was in my head:
  2. Jun 8, 2015 at 6:23 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    My thought, for now, is that the factory cleats would still be usable. Does this make any sense? Does anyone see any use for this, or should I stop hallucinating in my sleep?
  3. Jun 8, 2015 at 6:33 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    And did someone already suggest this to me? If you did, let me know so you get credit for it, and so you can get the first production piece on the house (as per KB Voodoo Fabrications company policy).
  4. Jun 8, 2015 at 6:39 AM
    Pigpen
    Dan
    Northwest Montana
    So, you're saying the factory track would be taken off and then remounted with this behind it? I'm trying to picture how the HiLift would mount to this differently than the factory track.
  5. Jun 8, 2015 at 6:45 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    That's the idea, but I'm wide open to suggestion.
  6. Jun 8, 2015 at 6:48 AM
    headhunter247
    headhunter247 Well-Known Member
    St. Louis, MO area
    18 Taco Double Cab TRD
    5100's all around, OME 888 and Dakars. ProComp Series 05. Cooper SST Maxx 275s.
    So this rail would be below the factory rail. In theory being able to hold more weight due to rigidity?
  7. Jun 8, 2015 at 7:02 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    It would sandwich between the factory rail and the bed. It should be capable of holding quite a bit of weight.
    It could also be a nifty place to mount crossbars. It could have mounting holes already in place for that.
  8. Jun 8, 2015 at 8:47 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    I was thinking the OEM rail would run right down the center of the Utility Track (that's what I'm calling it) to enable the use of the cleats.
    Do you see any use for this? In my state, they don't really let you do any offroading, so I'm not sure if this is useful to people who are allowed to live a life of adventure.
  9. Jun 8, 2015 at 8:53 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Maybe if it was supplied with a few Titan Straps it would be useful for holding things.
  10. Jun 8, 2015 at 8:56 AM
    rickoshay45
    rickoshay45 Well-Known Member
    Rick
    Sanford Florida
    2015 Camry SE
    It wpould have to be wide enough to rotate the factory cleats when mounting them.
  11. Jun 8, 2015 at 8:57 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Good call!!!
  12. Jun 8, 2015 at 9:33 AM
    rickoshay45
    Rick
    Sanford Florida
    2015 Camry SE
    Also I would prefer it below the rail. I want to be able to tie ropes and such to cleats.
  13. Jun 8, 2015 at 10:27 AM
    BLaPointe
    BLaPointe Well-Known Member
    Brandon
    Fairbanks, AK
    15 TRD Off-Road, White
    End cap on the rail is removable and you can just slide them out the end so rotating them in may not be necessary allowing for tighter tolerances
  14. Jun 8, 2015 at 12:38 PM
    crux
    crux Well-Known Member
    New Mexico
    OR
    Honeycomb composite sleeper platform.
    Increasing efficiency carrying gear is always of interest.
    Current projects I've been drafting up include;
    - Septer water can holder, able to tip and pour water as part of tail gate kitchen
    - Fuel can holder, Can't make it back from Enchanted Towers without a back country fuel stop
    - Axes, shovels, saws. Yes there is a need for these holders. Problem is quick easy access with theft deterrent
  15. Jun 8, 2015 at 12:46 PM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    All of my products are now being shipped with a Pit Bull puppy (male or female, your choice).
    Customers will be responsible for training of said puppy.
    DrFunker and crux[QUOTED] like this.
  16. Jun 8, 2015 at 2:27 PM
    BLaPointe
    Brandon
    Fairbanks, AK
    :rofl:Dare we ask what circumstances precluded this??
    Could use a drop through pin with a drill out component to fit a small lock on it instead of detent retention? Not amazingly super secure but still more than the smash and grab crews might put up with?
  17. Jun 8, 2015 at 3:54 PM
    crux
    New Mexico
    OR
    Thanks for the laugh, great response!
  18. Jun 9, 2015 at 8:46 PM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    I'm still not sure about this thing....
  19. Jun 10, 2015 at 4:33 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    It would definitely support an RTT with HD crossbars.
  20. Jun 10, 2015 at 7:53 AM
    Pigpen
    Dan
    Northwest Montana
    I think I'm still having trouble visualizing use of the product. I understand that the factory tracks nest in this item. Would a HiLift be mounted above the factory tracks, allowing the rail and bed cleats to still be used?
