Product Introduction - KB Voodoo Bed Rack
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KB Voodoo, Dec 2, 2015.
  1. Mar 6, 2017 at 10:53 AM
    #221
    basically_stock_
    basically_stock_ 3rd Shift Lurker
    Eric
    Iowa
    2009 TRD Sport, Free & Clear
    2" lift, SCS Ray 10, Falken Wildpeak's
    How would a trifold work with this? Not sure it would
    ChadsPride likes this.
  2. Mar 6, 2017 at 10:59 AM
    #222
    KB Voodoo
    KB Voodoo [OP] Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
  3. Mar 10, 2017 at 9:17 AM
    #223
    basically_stock_
    Eric
    Iowa
    Interested in photos of a long bed rack installed.
  4. Mar 10, 2017 at 9:27 AM
    #224
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Here's one.
  5. Mar 17, 2017 at 5:59 AM
    #225
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    UPDATE
    We are picking parts up from the laser cutter tomorrow, and then the process of working through our shipping backlog begins.
    You will start seeing emails with tracking numbers very shortly.
  6. Mar 21, 2017 at 7:13 PM
    #226
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
  7. Mar 23, 2017 at 6:35 AM
    #227
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    A lot of you are going to be receiving a large and heavy box in the very near future (if you haven't already).
    Here are some assembly tips
    - Lay out all the parts on the garage floor
    - Assembly the rack UPSIDE DOWN
    - Once it's all together, flip it over, and set it on the truck in one piece
    A small 1/4" ratchet with a 7/16" socket will make quick work of the bolting process. Just snug the bolts, no need to crank them down.
  8. Apr 3, 2017 at 12:10 PM
    #228
    Maximus Gradient
    Maximus Gradient Well-Known Member
    Sean
    East Bay
    Red Taco, OR
    Blacked out chrome, TRD exhaust, rear diff. breather, hood/engine bay LED light strip, 235/85R16 DuraTracs
    Had a little mod day yesterday:
    So I really wanted a tonneau under my mid-height rack to protect gear from the elements, but also wanted to maintain the cover's full functionality so I could easily open the bed when needed.
    I decided on a Literider because it doesn't require any real estate on top of the bed rails, thus reducing the need for significant modification to the tonneau's mounting hardware.
    Regardless, we ended up taking two notches out of each rail to accommodate the four mounting points for the rack. The only drawback is I had to mount the rails over the bed utility tracks (again, to accommodate the bed rack), but I never really use them anyway...
    Pics!
    Holding our breath and making the first cuts - no refunds from here on out!
    The fit around the rack mounts once installed
    Fit and finish
    Keeping that cardboard dry!
  9. Apr 3, 2017 at 12:16 PM
    #229
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Measure 26 times, cut once!!
  10. Apr 4, 2017 at 11:03 AM
    #230
    Maximus Gradient
    Sean
    East Bay
    Red Taco, OR
    It was definitely a departure from the factory instructions, but overall it wasn't that bad of a job. Just thought I'd share in case anybody is interested in a similar setup with a Voodoo rack.
  11. Apr 4, 2017 at 8:23 PM
    #231
    AsadaTaco
    AsadaTaco Member
    SoCal
    2014 Blue Ribbon DCLB TRD Sport
    Does your cover open with the bed rack installed?
  12. Apr 4, 2017 at 8:24 PM
    #232
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    No it does not. All access to the bed is through the tailgate.
  13. Apr 5, 2017 at 11:32 AM
    #233
    Maximus Gradient
    Sean
    East Bay
    Red Taco, OR
    If you're asking me - yes, it does. I had to do some modding to get it to this point, but it's fully functional and will roll open all the way to the cab as intended. Obviously, with the bed rack on there I won't be hauling any quads, water heaters, pianos, etc., but it's nice to have that extra open space and ease of access if needed. I mostly wanted this for protecting gear (camping, skiing, etc.) from the elements and "prying eyes" :spy:, so I anticipate it staying closed most of the time.
    Otherwise, without modifications, refer to what KBV said above regarding tonneau cover compatibility with his racks ^^^
  14. Apr 5, 2017 at 12:32 PM
    #234
    AsadaTaco
    AsadaTaco Member
    SoCal
    Thank you Maximus Gradient,
    I too would like to secure gear while the bed rack is installed. In long bed, I'd like to be able to access the front end of the bed without having to crawl or use a hook to pull everything out.
    I like my bak flip, but may have to look for other options with regards to a bed rack.
    Thanks!
    Maximus Gradient likes this.
  15. Apr 26, 2017 at 7:44 PM
    #235
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Prices:
    Short bed, Tall - $600
    Short bed, Mid Height - $550
    Long bed, Tall - $650
    Long bed, Mid Height - $600
    Order HERE
    ALL PARTS ARE NOW LASER CUT.
    Now able to work with tonneau covers with optional attachment brackets!!
  16. May 2, 2017 at 3:09 PM
    #236
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    You nailed it. Well done, Chad. Well done!
    KB Voodoo[OP] likes this.
  17. May 13, 2017 at 5:21 PM
    #237
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Prices:
    Order HERE
  18. May 17, 2017 at 8:39 PM
    #238
    joetacoma16
    joetacoma16 Active Member
    2016 tacoma trd OR access cab
    What type of modifications did you make to accommodate? Thank you!
  19. May 22, 2017 at 7:06 PM
    #239
    Maximus Gradient
    Sean
    East Bay
    Red Taco, OR
    Sorry, just saw this now!
    Like I said in my post above, I went with the Literider cover since it appeared to be the easiest/best choice from a design perspective for what I wanted to accomplish. Also, it was relatively inexpensive, so that was added assurance in the event I scrapped the whole thing :D
    Here's a pic of the standard mounting instructions for the cover's rails:
    You can see that it requires removing and remounting the stock utility tracks inside the cover's rails. This obviously would not work with the KB Voodoo rack - modding the tonneau seemed easier and less risky than modding the rack! Instead, I modified the installation procedure as follows (sorry, it's hand written and might not be clear; PM me if you want high res and a detailed explanation):
    Basically, by reversing the installation procedure and mounting the cover rails INSIDE the stock utility tracks I was able to accommodate the KBV rack and only reduce the distance between the cover rails slightly, still allowing the cover to fasten properly to the velcro and maintain side-to-side tension.
    Again, in my post above you can see I cut out notches in the cover rails so they would fit nicely against the KBV rack "feet" once affixed to the stock utility tracks without bending and looking chintzy. To mount, I reamed out the existing mounting holes and used the same size T-nuts and screws KBV includes for mounting to the stock utility tracks.
    Hope that was clear!?
    KapitanWalnut and KB Voodoo[OP] like this.
  20. Aug 10, 2017 at 11:14 AM
    #240
    KapitanWalnut
    KapitanWalnut Well-Known Member
    Kurt
    Colorado
    '16 DCSB TRDOR Inferno
    Thanks for taking the time to lay this out. I will definitely be doing a mod similar to yours soon! I've been eyeing the KB Voodoo Rack since I first caught wind of it. However, I was discouraged because I wanted to have an operable tonneau along with a rack but it didn't appear this could be done. However, your post has given me renewed confidence!
