Product Introduction - KB Voodoo Hi Rise Crossbars, for use with tonneau covers
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KB Voodoo, Nov 30, 2015.
  1. Feb 25, 2016 at 8:20 AM
    #501
    Spansfelder
    Spansfelder Well-Known Member
    Austin, TX / Germany
    05 4WD
  2. Feb 25, 2016 at 8:34 AM
    #502
    Ducman
    Ducman Active Member
    NJ
    2016 MGM Tacoma Limited 4X4
    will the Toyota Tacoma Hi Rise Crossbars, for use with tonneau covers (fits years 2005 - 2016) work with the Bakflip tri fold tonneau line, as the 2016 Bakflip products have lowered the cargo management rails on the 2016 models about and inch or so from their original position in the pick up bed?
  3. Feb 25, 2016 at 8:38 AM
    #503
    KB Voodoo
    KB Voodoo [OP] Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    If the spacing between the rail (across the truck) is the same, they should work.
    Maybe somebody with a Backflip can chime in....
  4. Feb 25, 2016 at 7:36 PM
    #504
    THECHIPPER
    THECHIPPER Active Member
    Blaine
    2011 TRD Acesscab
    Just ordered thank you
  5. Feb 27, 2016 at 6:32 AM
    #505
    TheTacoAdventurer
    TheTacoAdventurer Well-Known Member
    Boston, MA
    2018 DCSB TRD OR
    Forever modding!
    Where was this a year ago when I spent a good amount of $$$ for this same setup lol. Pretty sure I suggested this. Glad to see it's working out.
  6. Feb 27, 2016 at 6:37 AM
    #506
    TheTacoAdventurer
    Boston, MA
    2018 DCSB TRD OR
    Forever modding!
  7. Feb 27, 2016 at 6:58 AM
    #507
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    Nah. Twas me long before that thread was started.
    KB Voodoo[OP] likes this.
  8. Feb 27, 2016 at 7:28 AM
    #508
    TheTacoAdventurer
    Boston, MA
    2018 DCSB TRD OR
    Forever modding!
    Dang. Thought I had started something.
  9. Apr 21, 2016 at 8:15 PM
    #509
    CaliDevilDoc
    CaliDevilDoc Well-Known Member
    San Diego, CA
    2016 Barcelona Red TRD Off-Road 4x4. 1995 FZJ80
    OME nitrochargers, 886, and Dakars
    What's maximum weight capacity? Are there any competitors that can carry more weight?
  10. Apr 22, 2016 at 4:31 AM
    #510
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    I believe @Mobtown Offroad 's hi rise bars are a little stronger, but I haven't seen them in person.
  11. May 12, 2016 at 6:23 AM
    #511
    hobiecat111629
    hobiecat111629 Well-Known Member
    2015 Tacoma Access Cab
    Anyone had a chance to test these with an RTT?
  12. May 12, 2016 at 6:29 AM
    #512
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    I wouldn't suggest using them with an RTT.
  13. May 30, 2016 at 12:29 PM
    #513
    ThomasMore66
    Dallas/Fort Worth & Durango
  14. May 30, 2016 at 2:21 PM
    #514
    fshams
    fshams Well-Known Member
    Columbus, OH
    2012 Tacoma V6 4x4 TRD/TX PRO - DCSB
  15. May 30, 2016 at 2:48 PM
    #515
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    omaguz likes this.
  16. May 30, 2016 at 3:52 PM
    #516
    fshams
    Columbus, OH
    ?????? I've reached out to KB Voodoo a couple of times in the past few months with the same exact inquiry ("will this application fit a 2016 Tacoma and if not, are there any plans to manufacture one that does?")and the only answer I got was 'NOPE and NOPE"... Poor customer relation in my opinion.
    I don't believe anyone plans to copy "this guy's design".... Just a lost business opportunity.
  17. Jun 29, 2016 at 9:45 AM
    #517
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Price is $275 per set, plus shipping.
    Set includes four brackets, two crossbars, security wrench, T-slot nuts, and all other hardware.
    Order Here
    WORKS WITH 2005 TO 2016 TACOMA'S
  18. Jun 30, 2016 at 1:28 PM
    #518
    Cnort
    Cnort Member
    Germany
    '12 Texas Edition Tacoma
    So there I was cruising down the A7, when it hit...I should do a product review! So Chad has designed an exceptional product that holds up to the rigors of rough travel. I am not going to discuss the issues I have with his first gen set up, well because I chose to go that route (saved some $$$), and when I am home (on US soil) I will upgrade. So lessons learned: the bike mounts are more stable when placed laterally (outside for those anatomically challenged)...they seem to sway less when traveling on the Autobahn at 90+ mph (because I can). The cargo basket is mounted midline, and the only bounce or sway I have noticed with with rough terrain. I have about 150lbs up there with the bike. however I did notice it was a bit unsteady, when my fat ass was sitting in the cargo basket, but that wa sustem for shits and giggles!
  19. Aug 12, 2016 at 7:13 AM
    #519
    PaulK
    PaulK Life is hard. It's harder if you're stupid.
    Paul
    Pittsburgh, PA
    2013 Black Baja Access Cab
    Don"t see these on the website. Have they been discontinued?
  20. Aug 12, 2016 at 10:35 AM
    #520
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    They are being redesigned. Stay tuned for a very sweet new release.
