Products for plastic trim
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 808stateofmind, May 30, 2023.
  1. May 30, 2023 at 11:53 AM
    808stateofmind
    808stateofmind [OP] Well-Known Member
    Kona
    '22 Lunar Rock TRD OR 4x4 DCSB 6MT
    Eibach pro truck 2.0/2R lift kit 1.5" AAL OME/ARB UCA BFG KO2, 285/70-17 SCS Blaze 10, 17-8.5, -10 offset ECGS bushing needle bearing replacement Clutch accumulator disk delete Poor mans TRD intake, K&N 57 series intake tube, K&N high flow filter, TRD flow accelerator
    What products are you guys using to keep the plastic trim looking black and not grayish? My truck is pretty new and the black fender flares on my OR and the trim around the mirrors are already starting to look a little grey. Anyone use a ceramic plastic trim coat like cerakote or anything similar?
    TRDRed likes this.
  2. May 30, 2023 at 11:54 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
  3. May 30, 2023 at 1:53 PM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    Back to Black is a very good product and lasts weeks. I use the spray can version as it covers better.
    Kolohe07, 22 Sport and TRDRed like this.
  4. May 30, 2023 at 1:56 PM
    tacotroy17
    tacotroy17 Well-Known Member
    Dustin
    SoCal
    2017 DCSB TRD-OR
    TRDRed likes this.
  5. May 30, 2023 at 2:16 PM
    Mbtstaco
    Mbtstaco Well-Known Member
    2023 Tacoma Pro MGM
    This! Been using this on my jeep wrangler fender flares for years. They still look good.
    D.A.S. Taco and TRDRed like this.
  6. May 30, 2023 at 2:34 PM
    Molina67
    Molina67 Well-Known Member
    Ken
    2022 Tacoma SR5
  7. May 30, 2023 at 3:10 PM
    TRDRed
    TRDRed Well-Known Member
    Pacific Northwest Playground
    2020 TRD OR DC SB OTT Tune
    I've also used 303 for years, but the Taco I recently purchased had some weird faded bits on the fender flares, around the mirrors, etc. that 303 wouldn't bring back.
    So after a bunch of research I ordered Griot's Garage 10858 Black Shine Tire and Trim Restorer and actually used it just this morning. So far I'm very impressed. It smoothed out the grayish odd bits and made everything nice and satin black again. No idea how long it'll last. Some of the reviews said over a year... we'll see. But very happy with the results so far. Used it on some of the interior ABS as well as that odd textured material on the doors and over the glove compartment. Cleaned it all up very nicely as well. Left the satin sheen I prefer over the glossy/residue stuff other products leave.
    https://www.amazon.com/Griots-Garage-10858-Trim-Restorer/dp/B018S43LBY
    https://www.griotsgarage.com/black-shine-trim-restorer-8-ounces/
  8. May 30, 2023 at 8:43 PM
    BTL Y-Wing
    BTL Y-Wing Well-Known Member
    2020 Army Green TRD Pro
    Used the Mother's Back to Black and 303 UV Protectant others mentioned earlier and both work great for restoring and protecting the unpainted trim parts in my experience over the past couple years so far.
    TRDRed likes this.
  9. May 30, 2023 at 11:57 PM
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
    I don’t wash/detail the truck nearly as much as I should especially in fl. There is only 1 product I like that doesn’t need to be reapplied every couple washes or couple months. It’s not glossy/greasy, keeping the matte finish- gtechniq c4
    I can’t remember exactly when I last applied it but noticed the hood deflector greying/whitish so did a solid clean with meguiars heavy duty vinyl cleaner/scrub brush (because of the textured surface), isopropyl solution, c4. This time I’ve decided to add a top layer of turtles ceramic spray coating. This should last at least a yr (not garage kept). Need to do the windshield cowl next
    ace96, MGMDesertTaco and TRDRed like this.
  10. May 31, 2023 at 1:56 AM
    GunthorNC
    GunthorNC Well-Known Member
    2017 Tacoma Offroad Access Cab 4x4
    Solution finish. Other people recommending trim dressings doesn't really fix the issue. Just covers it up.
    Solution finish actually dyes the plastic black again. One of the only things that will. Look up the pictures. They are real. Those are actual real results. It's safe for glass and paint if you get it there, just wipe it off. The smallest bottle they have will last you years and years.
    Here's why I don't like the other stuff.
    Back to black, doesn't actually change the color of the plastic, just cleans it, and shines it. You wash it off, plastic looks like crap again.
    303 is freaking amazing, but it's not the correct product for the job, use solution finish, then coat it in 303 to protect from uv. 303 by itself isn't going to be at good of a result (but yeah 303 is amazing)
    Ceramic coatings are good too, but I'd apply them over plastic that I've already actually fixed the coloring on (solution finish)
    So, if you want the absolute best results (and have bookoo bucks) I'd:
    Wash all the trim with soap and water (grime), follow up with vinegar(calcium and stuff buildup) then rubbing alcohol (clean the oils and rest of the stuff off.)
    After that, use solution finish. Wipe on, wait, wipe off
    Let it dry for a day or so, ceramic coat it
    Let it dry for a day or 2, 303 it.
    303 everything else while your at it, its the shit, but no it won't restore your trim by itself. It'll just make it look better.
    808stateofmind[OP] and TRDRed like this.
  11. May 31, 2023 at 2:42 AM
    willee51
    willee51 willee51
    Bill
    Forest, VA
    2022 SR5 DCSB AT 4X4, 6-cyl MGM
    Cerakote Ceramic trim coat, lasts about 5-6 months for me:thumbsup::thumbsup:
  12. May 31, 2023 at 6:50 AM
    BillyE
    BillyE Well-Known Member
  13. May 31, 2023 at 11:30 AM
    TRD_Seeds
    TRD_Seeds Well-Known Member
    York, PA
    2019 Cement Tacoma TRD OR
    Adam's VRT
    TRDRed likes this.
  14. May 31, 2023 at 12:45 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    303 is garbage, washes right off and streaks on paint in rain. Cerakote last long time.
    MannyS and 808stateofmind[OP] like this.
  15. Jun 3, 2023 at 9:55 AM
    Bmw2Taco
    Bmw2Taco Well-Known Member
    2018 Blue 4x4 TRD Sport Premium
    My 2018 OEM tonneau cover is totally grey. Do you believe a 1oz bottle of Solution Finish will be enough? How should I apply to a large textured surface like this?
    TRDRed likes this.
  16. Jun 3, 2023 at 11:27 AM
    808stateofmind
    Kona
    Thanks, i appreciate the concise response!
  17. Jun 3, 2023 at 12:36 PM
    TRDRed
    I've never used Solution Trim Finish, but they have before/after photos of a bed cover like you described. Might be worth a try...
    https://trimrestorer.com/products/solution-finish-black-plastic-vinyl-restorer
  18. Jun 3, 2023 at 12:42 PM
    MGMDesertTaco
    I currently use 303, but yes it does wash off fairly easy. Adam's VRT, Jay Leno's Tire and Trim, Mothers Back to Black work, but are all greasy imo. I'd like to try a longer lasting ceramic like Gtechniq's C4 as I already have CSL and EXO V4 on the paint.
    TRDRed likes this.
  19. Jun 3, 2023 at 12:43 PM
    Clearwater Bill
    Billy
    Largo Florida
    Cerakote for outside plastics
    Klasse for inside plastics
    Raggtopp cleaner and dressing for the tonneau.
    After trying those I tossed my remaining 303.
    TRDRed likes this.
  20. Jun 3, 2023 at 12:44 PM
    MGMDesertTaco
