ProEFX Towing Mirrors
Discussion in 'Group Buys' started by mach1man001, Oct 17, 2012.
Thread Status:
Not open for further replies.
  1. Feb 3, 2013 at 5:27 PM
    #261
    supermike820
    supermike820 Member
    2007 Double Cab TRD Sport
    Billet Grill TRD Intake TRD Exhaust Stereo
    They were not to hard to install the bigger pain in the but was actually figuring out wires were the ones I needed. Just need my switch for the heat to come in. Looks good. Does anyone know if you have the DRL mod done if the signals would be on with both running and turn? Or are you able to run a 5 pole relay to have it switch from running light to turn signal?
  2. Feb 3, 2013 at 5:31 PM
    #262
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    DRL operation is going to depend on how your mods were done.
    Normal DRL mods only impact the front signals, and I believe tapping into the normal ports for turn signals on the mirrors comes from the taillights, so they would be TS-only.
    With factory DRL, you could tap into the front turn signals and that would give you DRL/TS, but it would not give you running lights.
    If you modded a factory system to provide running lights, DRL, and turn signal, then the operation of the mirrors is going to depend on which of the half dozen methods you used to make the mod.
  3. Feb 3, 2013 at 6:24 PM
    #263
    elclem21
    elclem21 Quebeker
    Clément
    Alberta, Canada
    2009 Tacoma TRD DCLB
    OME 885x front, TC UCAs, OME Dakars rear, 4.30 gears, Eaton Detroit Truetrac (rear diff), HomerTaco Raptor Style satoshi grill
    Probably, but they will still need to source the power mirror adjustment switch, as WE are going to keep them :D.
  4. Feb 3, 2013 at 6:29 PM
    #264
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I know what you mean... I broke one of the glass panels removing them. It was pretty tense when I got the new Sienna mirrors and had to pop them out of their plastic backing.
  5. Feb 3, 2013 at 6:30 PM
    #265
    Rich91710
    Rich
    Los Angeles
    08 Base
    That's easy.
    It's the connectors that aren't so easy to get.
  6. Feb 3, 2013 at 6:55 PM
    #266
    elclem21
    elclem21 Quebeker
    Clément
    Alberta, Canada
    You got me on this :p
  7. Feb 3, 2013 at 6:59 PM
    #267
    Rich91710
    Rich
    Los Angeles
    08 Base
    Yup...
    And I extended the harnesses on my motorcycle 20" and ran them inside my ape hangers... I think I can handle splicing some Molex connectors onto the mirrors.
  8. Feb 3, 2013 at 7:25 PM
    #268
    cdk
    cdk Well-Known Member
    san angelo,tx
    2012 PreRunner TSS
    BruteForceFab rear bumper, Ranch Hand front grille guard w/ led lights, leds here and there, seat covers, dash cover, console and handle covers, weathertechs, upgraded audio system, bed mat
    here is my truck and my brother's 04.5 2500.
    they are growing on me, much easier to see my trailer while backing up.
  9. Feb 4, 2013 at 5:53 PM
    #269
    a89aries
    a89aries Well-Known Member
    Alex
    London Ontario
    09 Tacoma TRD offroad
    I like the idea of running them as running lights. Hookup would be really easy too, just tie into any circuit that gets 12v when ignition is turned on. I'm sure they only draw a couple watts being LED.
  10. Feb 4, 2013 at 8:45 PM
    #270
    JayDawg
    JayDawg Christian Pastor. Need prayer,have questions? Ask
    Jay
    Sterling, Co. via San Diego, Ca.
    Tacoma 4x4 Access Cab TRD Off Road Package
    4-PIAA 80 Racing Series Off Road Lights, Randy Ellis Design Light Bar, Bilstein 5100 Shocks, Rear Leaf TSB, Mickey Thompson Classic Lock wheels, fog light mod, more to come...
    Even though the group buy is over, I am definitely interested in the ones with the heated mirrors and L.E.D. element in them in black . I have an 07' Tacoma so I will need to get the wiring harness too and hopefully it has good instructions.
  11. Feb 5, 2013 at 3:36 PM
    #271
    mach1man001
    mach1man001 [OP] eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    PM me your email address and I will send you the CC form.
  12. Feb 5, 2013 at 4:00 PM
    #272
    marcballz
    marcballz Well-Known Member
    Marc
    Mcallen,Texas
    08 PreRunner SR5 TRD
    Electrical: 24/7 aux pwr, cabin ac outlet, fog light on, 55 watt hids (5k), engine bay lights, dash color swap, led cab/footwell lights, Exterior: air compressor w/ dual tank & dual horns, toolbox, headache rack Audio: pioneer head unity 12" jbl sub , (4) db drive 6x9, 360 db amp, 600 dual amp
    hey rob can you please send me a receipt/tracking# when possiable
  13. Feb 5, 2013 at 4:21 PM
    #273
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    Sorry totally slipped my mind today. I'll send it to you tomorrow.
  14. Feb 5, 2013 at 5:48 PM
    #274
    mikedgw
    mikedgw Member
    Michael
    Citrus Heights
    06 Prerunner TRD Sport
    Undercover Tonneau Cover, PowerTech disk brakes w. stainless steel brake lines. ProEFX towing mirrors. K&N air filter. Billet radiator grill insert. Prodigy P2 brake controller.
    Thank you Rob, the mirrors came today. Installed and tested. Took for a test drive, no vibration and can see everything! It will take trial and error to find the optimum adjustment.
    Sorry the pictures aren't better.
  15. Feb 5, 2013 at 9:57 PM
    #275
    marcballz
    Marc
    Mcallen,Texas
    much appreciated!
  16. Feb 6, 2013 at 5:41 AM
    #276
    cchar
    cchar Member
    St. Albert, Alberta
    Tacoma
    Hey Rob..is there a tracking number for my shippment to come up to Canada?
  17. Feb 6, 2013 at 5:50 AM
    #277
    damnfingers
    damnfingers Well-Known Member
    Gene
    Mississippi
    2016 Limited 2x4 DCSB
    Ditto!
    Gene
  18. Feb 7, 2013 at 7:49 PM
    #278
    a89aries
    Alex
    London Ontario
    Timer relay is in, looks like it should do the job okay. 0-60m timer is a bit long lol, will prob just have it dialed into 5m.
  19. Feb 9, 2013 at 12:51 PM
    #279
    DPCardoza
    DPCardoza Well-Known Member
    Yuba City
    06 PreRunner Sport Long Bed
    Installed mirrors yesterday. Looks pretty good. They will be great for towing but the viability is much better even when you aren't towing.
  20. Feb 9, 2013 at 2:32 PM
    #280
    shawnd2
    shawnd2 Well-Known Member
    Shawn
    Toronto, Ontario, Canada
    08 Tacoma Access Cab 4x4 TRD Offroad
    Hi Rob,
    You get a chance to drop the mirrors off at USPS for us Canadians?
    I'm heading up to Cochrane snowmobiling this coming weekend. After reading all these great reviews I'm hoping they get here on time.
    Shawn.
Thread Status:
