Profender anyone running them
Discussion in 'Suspension' started by livel0veryde, Oct 20, 2011.
  1. Feb 17, 2013 at 8:20 PM
    #101
    THExBUSxDRIVER
    THExBUSxDRIVER Victory is reserved...
    GOO5E
    Old Man Tan!
    Not enough.
    Run em yet?
  2. Feb 17, 2013 at 8:40 PM
    #102
    thekernel114
    thekernel114 Well-Known Member
    Chilliwack, B.C.
    07 tacoma 4x4
    allpro long travel, shackle flip with ome dakars, cruisin offroad bumpers and sliders, 4.88 gears with arb's front and rear, budbuilt skids.
    Yeah they ride nice, as good as my icons did even over the rough stuff
  3. Feb 18, 2013 at 4:46 AM
    #103
    Profender
    Profender Well-Known Member
    Thanks for the pics, Do you mind if I post a couple on FB?
  4. Feb 18, 2013 at 9:14 AM
    #104
    thekernel114
    Chilliwack, B.C.
    07 tacoma 4x4
    Yeah you can use them. I have no problem with that
  5. Feb 18, 2013 at 11:45 AM
    #105
    THExBUSxDRIVER
    GOO5E
    Old Man Tan!
    Not enough.
    Any tuning needed?
    I want to get 16" rears but worried that shims and stuff will not be readily available.
  6. Feb 18, 2013 at 12:16 PM
    #106
    thekernel114
    Chilliwack, B.C.
    07 tacoma 4x4
    They ride good without tuning but these were valved for the Tacoma, the generic shocks from profender will just have base valving and need to be tuned to suit your needs. Profender has all the shims in stock as far as I know just not listed on the site.
  7. Feb 26, 2013 at 8:45 PM
    #107
    Oowen
    Oowen Well-Known Member
    Owen
    Reno, NV
    '24 F-150
    Can I run the toytec/eibach coils? Thanks
  8. Feb 26, 2013 at 9:55 PM
    #108
    thekernel114
    Chilliwack, B.C.
    07 tacoma 4x4
    If you can run the eibach coils on stock struts, bilstien 5100's, or ome struts then they will fit on these shocks. The profender shocks are meant to run stock coils and I'm running ome 885x coils without issue.
  9. Feb 26, 2013 at 10:08 PM
    #109
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    whats the largest bypass you make? and how many tubes can you go up to?
  10. Feb 26, 2013 at 10:10 PM
    #110
    tostidos
    Apple Valley, CA
    07 LT 6spd
    also what kind of warranty do you guys offer for the people who use their shocks and beat on them the way they are intended?
  11. Feb 27, 2013 at 4:59 AM
    #111
    Profender
    Yes, they are made for use with stock type coils, so if they fit the stock shock they will fit our shock.
    2.5 bypass is the largest, 1-year against manufacturing defects.
  12. Feb 27, 2013 at 6:36 AM
    #112
    Oowen
    Owen
    Reno, NV
    '24 F-150
    Thanks!
    1. How is the ride quality?
    2how much lift did you gain?
  13. Feb 27, 2013 at 6:40 AM
    #113
    tostidos
    Apple Valley, CA
    07 LT 6spd
    Well goodluck with the new product, curious to see how they handle. When do you plan on going to bigger shocks like 3.0 x 18s and such?
  14. Feb 27, 2013 at 7:16 AM
    #114
    Profender
    Thank you sir. No plans to go bigger right now.
  15. Mar 1, 2013 at 10:14 PM
    #115
    thekernel114
    Chilliwack, B.C.
    07 tacoma 4x4
    The coilovers are at the lowest setting but the ome 885x coils gave me 2.25 inches, just waiting for my wrench to arrive so I can adjust the collers to level the truck side to side.
  16. May 13, 2013 at 10:03 AM
    #116
    livel0veryde
    livel0veryde [OP] Well-Known Member
    josh
    missouri
    Tacoma based buggy
    What happend to the first gen coilovers? That still in the works?
  17. Jun 27, 2013 at 9:54 AM
    #117
    NwiTACO
    NwiTACO Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
    Will your bump cans fit 2.0x4" Fox bumpstops?
  18. Jun 27, 2013 at 10:22 AM
    #118
    Profender
    I am not sure the dimensions of the Fox bumpstop but our bumpstops are 52mm O/D.
  19. Jun 27, 2013 at 11:44 AM
    #119
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    52mm = 2.04 inches.... should fit, fox is 2" OD on the 2.0's
  20. Jun 29, 2013 at 10:49 PM
    #120
    livel0veryde
    josh
    missouri
    Tacoma based buggy
    Ttt
