Professional Opinion Needed: Spacer with 5100's! Good or Bad? Does it really matter?
Discussion in 'Suspension' started by w8n4mud, Nov 5, 2009.
  1. Nov 5, 2009 at 12:24 AM
    w8n4mud
    w8n4mud [OP] I'm back.
    Albert
    Chula Vista, CA
    2019 Tacoma Off Road DCSB
    Stock. Purchased 2/17/19. Cement!
    Here's the scoop. I currently have this spacer kit on the front.
    I went to a shop where my Bilstein 5100's were going to be installed. The Bilsteins were already set at 2.5 and were lowered to accomdate the spacer kit. :eek: What? Yeah that was my reaction. I assumed that the shop was going to remove the spacer kit when I wanted the upgrade, but they didn't.
    So to make a long story short, am I losing/gaining anything by having this set-up? The shop is willing to go back in and undo the spacer kit and lift the struts back to 2.5, but is that really needed? It's level right now and looks higher than it did before. Just wondering if there is an advantage or disadvantage. I'm looking for opinions from people who know suspensions. Thanks guys.
  2. Nov 5, 2009 at 1:02 AM
    ROCKSLINGER
    ROCKSLINGER Zombie Response Team
    Robert
    Reno Nv
    14 MGM DBL CAB 6 SPEED
    Fox Coilover with reservoir, Fox Remote Rear reservoir, Wheeler's 3 pack AAL, Grillcraft Grille color matched, Rampage 50" LED Light Bar, Relentless 1/4" IFS-Mid and Transfer case Skids, Relentless High Clearance Rear Bumper, Kenwood 1800 watt Amp, 12" Rockford Fosgate P3 Shallow Sub, 1 Farad Capacitor, Redline Hood Struts, Weathertech Floor Mats, Doug Thorley Long Tube Headers, Flowmaster Delta 40, URD MAF Calibrator, URD Short Shifter, CST Black Leather W/Red Stich, On Board Air, Train Horns,
    :popcorn:
    Im curious as well Just did mine myself with my spacer set them at .85 so far so good. Sits higher but is rougher.
  3. Nov 5, 2009 at 1:12 AM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    I'd say don't do it.
    You're basically stacking lifts, which could lead to some problems.
    I say remove the spacers and put the 5100s at 2.5. :thumbsup:
  4. Nov 5, 2009 at 7:53 AM
    Padilla1880
    Padilla1880 "Let's Ride!"
    Daniel
    Temecula, CA
    05 TRD OffRoad V6 SR5 PreRunner
    Spacer lifts sit on top of the coils, which puts more load on the coils, causing for a less than satisfactory ride. Since the 5100's are set at 0/lowest notch, the spacers are still providing the lift while the 5100's provide the smoother ride due to the valving on them. Essentially your still a spacer lift.
    Setting the 5100's higher gives it more preload causing for a stiffer ride.
    Setting the 5100's higher along with the spacer puts a ton more load on the shock/strut as well as the coils, which will give a horrible/unsafe ride.
    Al I would advise against stacking like Derek said. Remove the spacers!
    Or you could get some of those Eibach lift springs and leave your 5100's at 0/lowest notch.
  5. Nov 5, 2009 at 7:55 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Those top plate spacers lead to breakage if you go off road.
  6. Nov 5, 2009 at 8:17 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    On a good bump the shock will bottom out before the suspension hits the bumpstop. Do it hard enough and you'll break the only thing holding up the front end of your truck. Get the spacer out of there.
  7. Nov 5, 2009 at 8:22 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  8. Nov 5, 2009 at 8:32 AM
    SLOH
    SLOH Well-Known Member
    Scott
    Los Angeles
    07 SR5, dc long bed speedway blue
    2.5 Icon c/o's and 3" AllPro rear suspension kit, 17" XD Series Addict w/ 285/70/R17 BFG KM2's, K&N 63 Series CAI, 13.5'' JL Sub (13TW5v2-2) and 500w Rockford Fosgate amp, limo tint all around, cat back banks exhaust with no muffler or tip, blue dash light mod, "taco" 3rd brake light mod, blue dome-light mod, cb radio and 4' firestik antenna, blacked out hoodscoop(thanks randy), Total Chaos UCA's
    hey...that looks familiar haha and yeah al i'm surprised they didn't take the spacer out for you, bad juju
  9. Nov 5, 2009 at 10:38 AM
    w8n4mud
    Albert
    Chula Vista, CA
    Little update: I parked head-to-head with Ron yesterday and originally his truck was slightly higher than mine (he has 5100's). Mine now sits almost 1.5 higher even though the strut is not at 2.5. I don't think it's at its lowest level. I'm not a hard core off-roader. I do like the occasional venture to the dirt trails. One reason I was debating was because of my stance right now. I will go down a little. The ride right now is as smooth as a baby's butt.
  10. Nov 5, 2009 at 10:42 AM
    derekabraham
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    I hope it doesn't break in Ocotillo. :eek:
  11. Nov 5, 2009 at 11:05 AM
    w8n4mud
    Albert
    Chula Vista, CA
    Would lifting the truck up with a jack allow me to see how much travel I have before the suspension hits the bumpstop?
  12. Nov 5, 2009 at 12:00 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    It's not the downward droop or extension that he's referring to.
    Top plate spacers force the entire suspension travel into a different position/lowered.
    It's the UPWARD travel ....
    You'd have plenty of downward droop but not enough UPWARD travel. Hence, the suspension/strut would compress & bottom out first.
    (hard to explain).
    Your options would be.....
    #1) Install 5100's at the STOCK setting with the top plate spacer
    OR
    #2) Remove top plate spacer and adjust 5100's to desired height
    Do NOT DO BOTH
  13. Nov 6, 2009 at 11:00 AM
    w8n4mud
    Albert
    Chula Vista, CA
    Done. I took your advice and had them removed.
  14. Nov 6, 2009 at 11:02 AM
    derekabraham
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
  15. Nov 6, 2009 at 11:04 AM
    Padilla1880
    Daniel
    Temecula, CA
  16. Nov 6, 2009 at 11:20 AM
    w8n4mud
    Albert
    Chula Vista, CA
    Ready for Ocotillo
