Program New Key Fob, How To?
Discussion in '1st Gen. Tacomas (1995-2004)' started by TACO in SC, Oct 18, 2023.
  1. Oct 18, 2023 at 5:23 PM
    TACO in SC
    TACO in SC [OP] TuRD
    Andrew
    Greenwood, SC
    '03 Tacoma Ex Cab 4x4 V6 5-Speed
    Pretty well stock
    I still have the two key fobs that came when I bought my new '03 Tacoma, and they still function well. But they're suffering pocket wear and are bulky. Recently I bought a couple new key/fob combos but I've been unable to program them.
    Two of these:
    https://www.ebay.com/itm/264148686092?fits=Year:2003|Model:Tacoma
    I have followed this procedure a number of times but the power door locks never lock and unlock to indicate it's ready to accept the new remote.
    https://www.keyfobprogram.com/2003-toyota-tacoma-remote-programming/
    Is there another programming method I could/should use?
  2. Oct 18, 2023 at 5:41 PM
    jrallan26
    jrallan26 Well-Known Member
    Iowa
    2004 White D-Cab TRD
    Have you thought about getting new covers for your fobs?
  3. Oct 18, 2023 at 5:44 PM
    TACO in SC
    Andrew
    Greenwood, SC
    Pretty well stock
    I have and may end up with new covers. But I would like to use the new key with fob combos that I bought.
  4. Oct 18, 2023 at 5:47 PM
    jrallan26
    Iowa
  5. Oct 18, 2023 at 6:39 PM
    TACO in SC
    Andrew
    Greenwood, SC
    Pretty well stock
    The above linked video follows the same written instructions I linked in my original post. It hasn't worked for me. I'm trying to discover what I may be doing wrong or are there other procedures I might try.
  6. Oct 18, 2023 at 6:40 PM
    jrallan26
    Iowa
    Check and see if you have the correct FCC#.
  7. Oct 19, 2023 at 8:39 AM
    TACO in SC
    Andrew
    Greenwood, SC
    Pretty well stock
    I'm reasonably sure I have the correct new fobs. My concern is the truck never gets to step 5 that says:
    "5. Within 3 seconds, the power door locks should lock then unlock automatically indicating successful entry into programming mode." This auto lock & unlock never happens, so I believe the problem is in the truck program process.
    If the auto lock & unlock happened, and then it didn't accept the new remotes, I'd be placing the blame on them.
  8. Oct 19, 2023 at 1:23 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    I'm going to guess that the 'FOB' you bought is incompatible with the RS3200. Do the FCC ID's match?
    Anyway, here are the stock programming instructions. I didn't compare to what you linked to so...
  9. Oct 20, 2023 at 10:00 AM
    TACO in SC
    Andrew
    Greenwood, SC
    Pretty well stock
    Those stock reprogramming instructions follow the same steps as my earlier post. My truck doesn't react with the auto door lock & unlock when I go through these steps. That's what puzzles me. I don't believe the truck has any sensors to recognize the presence of a key fob, but maybe I should try this absent of my functioning fobs.
    I'm in contact with the seller of the new fobs, we'll see what he says.
    Thanks for all your help.
  10. Oct 27, 2023 at 1:59 PM
    TACO in SC
    Andrew
    Greenwood, SC
    Pretty well stock
    The seller of the key fobs gave me the same instructions I already had, and no additional help, so no new developments.
    :annoyed:
    So, I'll just shelf this until later.
  11. Jul 30, 2024 at 1:18 PM
    ->M^X<-
    ->M^X<- New Member
    09 4cyl 5lug
    I'm having the same problem with my 09 except I can't lock my doors anymore. Did you ever find a solution?
  12. Dec 7, 2024 at 4:22 PM
    TACO in SC
    Andrew
    Greenwood, SC
    Pretty well stock
    No, I did not find a solution. I'm willing to try again if someone has some helpful hints.
